Tyvek Homewrap - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-08-2010, 04:22 PM   #16
Framing Contractor
Originally Posted by GBR in WA View Post
The inspections have to follow the correct order, as per B.D. Usually: frame inspection (the windows are already in as the framer installs these); mechanical (HVAC)/ plumbing, electrical, etc.... Some builders schedule frame separate rather than same time as mech/plumb, easier on the inspector for trips made. After frame, you can install wrap to dry-in for electrical sub. Some areas sheath walls and paper/wrap gables only before electrical work.
Be safe, Gary
Gary,
Around here in NJ you don't get a framing inspection until plumbing and electrical is done.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-10-2010, 11:05 PM   #17
Registered User
Rewards Points: 5,492
Good catch, Joe. I should have said shear wall inspection...... Sorry for my confusion.
Be safe, Gary
Tyvek and roofing felt bamaranch Building & Construction 17 05-26-2010 03:00 PM
deteriorating tyvek DangerMouse Building & Construction 31 02-26-2009 11:12 PM
Stucco contractor cut up all my Tyvek! What to do? Gatorback Building & Construction 9 10-20-2008 05:43 AM
Tyvek application in crawlspace libwes Building & Construction 3 03-27-2008 11:45 AM
Tyvek RickT Building & Construction 4 03-15-2007 06:06 AM
