Old 03-14-2007, 11:59 AM   #1
Tyvek
I'm having my house resided. The house is 12 years old, and the aluminum siding was damaged by hail. No house wrap was originally installed. I asked my contractor to use Tyvek under the Hardie Plank cement fiberboard siding. He said that's what he uses. He's siding another house next to mine, and he's using PrimeWrap in some spots and BuildersChoice wrap in other spots. I asked him to confirm he would be using Tyvek on my house and why he wasn't using it on my neighbor's house. He said he is using Tyvek, and that it just has a different label on it. Are all house wraps equal? Is Dupont actually producing house wrap and putting different labels on it? Should I insist he use Tyvek?
Thanks,
Rick
RickT is offline   Reply With Quote
Old 03-14-2007, 12:54 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Tyvek
Yes, I'm sure what he is telling you is the truth and is accurate. See more points regarding this below....
While they all claim to address the same issues and accomplish the same goal....they are not all made the same.
Example: http://www.csfabric.com/comparison.htm
Yes, Manufactures such as Dupont, are providing services to 'print' logos, builder's names, supplier's names, etc.... on the wrap itself for advertising purposes.... I believe that is how you observed the 'Builder's Choice' labeled house wrap (Tyvek).
Example: http://www.weekesforest.com/primewrap.htm
Rick
That is up to you. You can do research on some of the house wraps out there. Here are some, Take your pick:
http://www.typarhousewrap.com/
http://www.owenscorning.com/around/i...s/pinkwrap.asp
http://www.pactiv.com/green-guard/
http://www2.dupont.com/Tyvek_Construction/en_US/
- Build Well -
Old 03-14-2007, 09:55 PM   #3
Tyvek
Rick,
I can't comment on exactly what the builder you are planning on going with is using, but if your interested in some of the various properties of the housewraps that are out there, take a look at a recent article that was published in Fine Homebuilding. You can find it by going to www.taunton.com/finehomebuilding and searching for "housewrap". The article was written by Fernando Pages Ruiz. It's actually quite informative.
mebsdad is offline   Reply With Quote
Old 03-14-2007, 10:12 PM   #4
Tyvek
Originally Posted by mebsdad View Post
Rick,
Thanks for that reference article ....
- Build Well -
Old 03-15-2007, 07:06 AM   #5
General Contractor
joasis's Avatar
Tyvek
It is funy that the tried and true felt paper is still being used....I install housewrap.....typically Tyvec, and didn't know there was that much difference....so we learn something new veryday.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Siding and Brick veeneer wall? sandyman720 Building & Construction 9 08-13-2007 05:02 PM
Installing Tyvek Home Wrap? sandyman720 Building & Construction 7 07-31-2007 12:34 PM
Re-siding house jdig Building & Construction 5 04-10-2007 10:15 AM
Best Ext. Sheathing: Rigid Foam An Option? austinbirdman Building & Construction 3 12-15-2006 10:02 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
