Tyvec!!! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-29-2009, 08:55 AM   #1
tyvec!!!
Well. I've learned that tyvec house wrap should always be used, Now what I'm wondering is,is Tyvec the name brand house wrap the best option? Ive read on the web, its woven opposed to perforated.....?
fricandfrac is offline   Reply With Quote
Old 03-29-2009, 10:03 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
i think alot depends on what kind of siding your doing and how its being applied,ive seen every thing from rosin paper to tyvek and ive come to belive its all in the details on how the wrap is applied is more important than the material itself
Tom Struble is offline   Reply With Quote
Old 03-29-2009, 10:10 AM   #3
Remodeling Contractor
The woven tyvek is what you are looking for. Others are for commercial applications where it may be left exposed longer. Also if using stucco or stone or brick a different wrap altogether is used in addition to the house wrap. The house wraps for used as a weather barrier to prevent wind driven moisture to enter the building envelope. But this will only work if careful attention to the installation details are followed. Especially around the windows.
Old 03-29-2009, 01:20 PM   #4
Registered User
Rewards Points: 526
I agree with Bob. Here is some reading for you. http://www.dickseibert.com/martin.pdf and http://www.umass.edu/bmatwt/publicat..._barriers.html Be safe, GBAR
Old 03-30-2009, 07:01 PM   #5
The tyvec in my situation would be used behind horizontal steel dutch lap house siding.And hope for the best I guess as far as the window flashing goes. I would love the imput about tyvec vs any other plastic type house wrap (off brand that is) Thanks
Old 03-30-2009, 07:58 PM   #6
Rewards Points: 162
Like someone else mentioned, the installation quality is far more important than the brand - properly taped joints, returns at windows and doors, etc.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 03-30-2009, 10:41 PM   #7
Rewards Points: 150
When I resided my house I went to Carter Lumber for tyvek, and the girl got me with "carter wrap is half the price and just as good..." so I went with it.
Went all summer with it exposed, it held up fine. it's heavy woven plastic fibers, damn strong. As long as it don't fall apart in there over the years, I don't see how anything could do any better of a job?
Nothing was there to begin with so no matter what it's better than it was
johnnyboy is offline   Reply With Quote
Old 03-30-2009, 11:24 PM   #8
Registered User
Rewards Points: 526
Compare: http://www.umass.edu/bmatwt/publications/articles/
housewraps_feltpaper_weather_penetration_barriers. html
This compares 7 different wraps, if that doesn't have your off-brand, I wouldn't recommend it. Be safe, GBAR
Drafty House - adding tyvec to a nine year old vinyl sided house? songbird_63366 General DIY Discussions 8 02-10-2009 04:21 PM
