Old 08-01-2012, 11:47 AM   #1
Types Of Garage Archways
Hi there, this is my first post, here goes.
I've built a garage with a 9' wide door and the plans call for an arched brick front. My dillema is this, do I keep the doorway square and add a couple of 2x8's on top and that are cut with an arch shape or do I make the arch in the doorway with plywood cut to an arch and add an angle? I'm not too crazy about having a couple of 2x8's on top of the door covered with aluminun flashing. Any ideas? I've already started cutting the plywood with a trammel just to see how hard it would be.
Thanks for your input and any ideas that you come up with.
BarryBudd is offline   Reply With Quote
Old 08-01-2012, 03:46 PM   #2
Assuming the garage is single storey; js the brick arch to be a true, structural arch (ie self-supporting) or is it going to be just decorative, with a permanent arch-shaped form underneath?
I can't follow the point about the al. flashing, and also the 'angle'.
Pic. would help.
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
mae-ling (08-01-2012)
Old 08-02-2012, 12:12 AM   #3
GBrackins's Avatar
please check out this link, especially Figure #4 http://faculty.arch.tamu.edu/anichol...1brickarch.pdf
you can use a curved steel arch to support the brick
hope this helps .....
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
Cooling the Garage steveKane HVAC 9 09-02-2011 03:31 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 02:50 PM
Insulate finished garage ceiling or condition garage? pasichnyk Building & Construction 19 12-06-2010 02:46 AM
Garage Ideas? tripflex General Discussion 13 12-16-2009 08:06 PM
