Type Of Wood For Soffit/fascia - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-11-2013, 12:55 PM   #1
Rewards Points: 248
Type of wood for soffit/fascia
Hello, I need to replace a board on my soffit/fascia. It is the angle piece on the end that I need to replace. Is there certain wood to use for that piece? I read that plywood might soak up water if it gets wet. i will be painting the one I replace.
I put a link on here to show what I am talking about. This is not my house, just an example of the piece I need to replace.
http://www.capstonebros.com/soffit-fascia
jburchill is offline   Reply With Quote
Old 07-11-2013, 01:22 PM   #2
Rewards Points: 980
For painting and retaining paint Poplar would be my choice.
Old 07-11-2013, 02:24 PM   #3
Rewards Points: 248
Is that more of a specialty wood? I'm looking to go to home depot or lowes or something and get something.
Old 07-11-2013, 02:53 PM   #4
Poplar is popular at HD & Lowe's
RoyalAcresRod is offline   Reply With Quote
Old 07-11-2013, 03:37 PM   #5
Rewards Points: 980
As with any wood for painting we would like to have quarter sawed when possible. Poplar often lacks visible grain that makes cut identification as possible as other woods. Example: Yellow Pine, so try to avoid any lumber with a cup. Cupped Poplar is usually plain sawed.
Old 07-11-2013, 03:55 PM   #6
Framing Contractor
Rewards Points: 118
Pvc trim is probably your best option. It will look just like wood, and even comes in sizes that match dimensional lumber. It will never rot, is easy to work with and accepts paint nicely.
sixeightten is offline   Reply With Quote
Old 07-12-2013, 05:59 AM   #7
roofingquotes's Avatar
I'd go for HD & Lowe'.
roofingquotes is offline   Reply With Quote
Old 07-12-2013, 08:13 AM   #8
Rewards Points: 248
I put another pic of the piece i am replacing..Not sure from the original link i posted if there was some confustion.. I am replacing the triangle piece. I would like to keep it with wood, since the rest of them on the house are wood.
Type of wood for soffit/fascia-untitled.jpg
Old 07-12-2013, 08:56 AM   #9
AHH, SPANS!!!
Rewards Points: 1,166
you'll have to measure down from the underside of gable/rake fascia at the same plane of the roof pitch down to the lowest point of the gable corner soffit return to determine what size board you will need. do not use plywood as that will sponge and de lam. if the return is larger than 1x10 you will have to build it in two pieces or use cpvc 1x12 to get the cut. about $60 for a 12' piece at the box stores...
you can cut the piece square first a little longer than needed and hold it up there butted to the bottom of the rake fascia and use a 2' level to find the bottom level section that is level with the underside of the fascia where the return starts and scribe it with a pencil and then for the plumb section scribe the backside of your piece where the return goes back to the wall, I always add 3/8" or 1/2" past the that point to allow a reveal on the backside of your return.
Also, after you have scribed it and it is ready but before you nail it on make sure the spacing from the back side of your piece to the wood framing is accurate. you might have to put a few shims behind there to keep it consecutive so your piece sits tight and flush to the front bottom edge of the rake fascia. nail up through your piece to the rake fascia at the outer points first- vertically up through and then nail the face of it, this helps keep it lined up with the rake fascia too.
hand drive is offline   Reply With Quote
Old 07-13-2013, 08:05 AM   #10
firehawkmph's Avatar
Rewards Points: 1,858
You should update your profile so we know where you are located. Around here in northern Ohio, pine and poplar don't hold up well for outdoor use, even when painted. Redwood or cedar for house trim if you want to stick with wood. Both hold paint well if prepped properly, and are rot resistant. I don't think the box stores carry redwood, but they do have cedar up to a 1 x 12. If you have a real lumberyard in your area, they should have redwood.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Type II base for a big wood stove Earthling Building & Construction 4 02-25-2013 04:30 PM
What type of wood flooring is this? duncan20 Flooring 6 01-24-2012 10:35 AM
Confusion about wood type toxicprison Remodeling 3 01-19-2011 02:21 PM
What type of wood flooring in basement to use spaceman spif Flooring 4 09-02-2010 12:54 PM
