Old 12-07-2008, 07:25 PM   #1
Type of nails for exterior trim
The siding looks like this.
The cedar trim is placed 16" oc. The siding is just 8x4 sheets of plywood type wood. The trim is just used to cover the seams and nails. Can I use 2" galvanized finish nails? I do have 2 1/2" galvanized ring shank nails. It was originally fastened with spiral nails.
bluefitness is offline   Reply With Quote
Old 12-07-2008, 08:21 PM   #2
Moderator
Termite's Avatar
8d ring shank galvanized nails should be used to fasten the sheets of siding to the studs. That's a code requirement. The same 8d's will suffice for fastening the cedar 1x as well.
Old 12-07-2008, 09:01 PM   #3
Yeah, I knew about the siding. I wasn't sure if I could get by with the trim boards. The nails in the trim become visible after a few years.
Clipped Head v. Full Round Head Nails RickT Carpentry 10 11-18-2010 10:00 AM
Size/Type of Nails for Interior Framing? mfleming Building & Construction 2 09-16-2008 09:39 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 11:31 PM
Rusty nails FatAugie Roofing 6 08-28-2007 10:25 AM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 11:54 AM
