-   -   Type of nails for exterior trim (http://www.diychatroom.com/f19/type-nails-exterior-trim-33350/)
bluefitness 12-07-2008 07:25 PM
The siding looks like this.
http://www.home-improvement-tip.com/...yl_battens.jpg
The cedar trim is placed 16" oc. The siding is just 8x4 sheets of plywood type wood. The trim is just used to cover the seams and nails. Can I use 2" galvanized finish nails? I do have 2 1/2" galvanized ring shank nails. It was originally fastened with spiral nails.
Termite 12-07-2008 08:21 PM
8d ring shank galvanized nails should be used to fasten the sheets of siding to the studs. That's a code requirement. The same 8d's will suffice for fastening the cedar 1x as well.
bluefitness 12-07-2008 09:01 PM
Yeah, I knew about the siding. I wasn't sure if I could get by with the trim boards. The nails in the trim become visible after a few years.
