Type II Base For A Big Wood Stove - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 01:08 PM   #1
Type II base for a big wood stove
I posted this in the HVAC forum, but maybe it should have gone here.
Anyway ... Hi all! I just bought a wood stove and will need a Type II hearth pad/base for it. (Type II because it's a big-a** stove that'll heat the whole house.) I could buy a pre-fab one, but I'm already over budget and would rather not spend an addtional 6 or 7 hundred.
So here's my question: Can I just put down three or so layers of durock or hardieboard, another couple layers up against the wall, and tile them with inexpensive ceramic from the Big Orange (or Blue) Store?
Stove is going on the lower floor, which has a concrete base with laminate wood flooring. The walls still have the 70s wood paneling, keeping them but painting them so the room doesn't look like a dungeon.
Any opinions / advice / wisecracks welcome.
Earthling is offline   Reply With Quote
Old 02-24-2013, 01:54 PM   #2
Rewards Points: 150
Manufacturer's Specifications
With any heating appliance that is a "listed appliance" there will be specifications from the manufacturer that provides the installation details. It will specify the distance to combustible surfaces and non-combustible surfaces, also referred to as protected surfaces. These specifications vary depending on the size of the stove, fuel, if it has a heat shield and whatever else factored into the testing of the stove. Check the manufacturer's installation specifications and install to that. If your municipality requires a permit for the installation then you will likely need to submit the specifications to them with the permit application. Some homeowners insurance policies require you notify them when you install a fireplace or stove. It probably will not be a factor with your stove but note if the manufacturer's specifications refers to non-combustible surfaces or non-combustible construction, they are different. good luck.
TheCamper is offline   Reply With Quote
The Following 2 Users Say Thank You to TheCamper For This Useful Post:
Earthling (02-24-2013), jaydevries (02-25-2013)
Old 02-24-2013, 04:00 PM   #3
Hi there Camper! According to the specs, with the rear heat shield (which comes standard), 'Rear clearance is 7" to combustible wall with top vent/ rear shield'. Still, they recommend going bigger than the standard 54x54 corner hearth pad, they suggest 60x60.
Here's the beauty:
http://www.woodstove.com/progress-hybrid
Forgot about permits, will check on that tomorrow, thanks.
Old 02-25-2013, 06:43 AM   #4
Rewards Points: 3,130
That is a nice looking stove. Ours is about that size but has no glass in the doors. Having had stoves in several of our houses, I suggest you consider a raised hearth. That makes loading the stove much easier on the back. Ours is raised just six inches and it makes a world of difference.
Oddly enough, I had to get a permit and inspection for the chimney, but nothing for the stove installation itself. My homeowner's insurance went up about $40 a year.
Old 02-25-2013, 04:30 PM   #5
Seriously? Not for the stove itself? ::scratches head:: Go figure.
Re the insurance, I checked with my rep before I bought and he said no increase ... and he used the same installers for his stove.
PS - good idea about the raised hearth - the same principle applies to my new stacked washer/dryer set. My back thanks me!
Last edited by Earthling; 02-25-2013 at 04:32 PM. Reason: general absentmindedness
Tags
hearth pad , wood stove
Installing a wood burning stove. rickjames8 Building & Construction 13 10-30-2012 10:02 PM
adding wood stove to boiler flu? wombosi HVAC 7 12-14-2009 05:27 AM
Wood Stove Blower question Alan HVAC 6 11-27-2009 09:49 PM
wood stove insert Karpol General DIY Discussions 5 11-25-2007 11:56 AM
Comment on those Special Type of Treated Wood for Deck ? KUIPORNG Landscaping & Lawn Care 4 07-04-2006 12:38 PM
