Type Of Cement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 08:33 PM   #1
Type of cement
I'm making my basement useable. So I moved all the mechanicals into a corner and have partioned them off using a frame/drywall wall. I had my plumber install a floor drain near the mechanicals. The old floor drain is in the middle of the basement so I want to
1) fill in the old drain
2) level off the area around the old drain
3) Create a curb around the partion to prevent any possible flooding and do some floor masonry to have the floor near the mechanicals slope toward the new drain
I'm trying to do research and will be going to the library soon. Can anyone recommend any good places on the internet or materials/advice on this project? Or even a complete step by step and materials list. That would be awesome.
I plan on putting tile over this area. The area where the old drain is probably 4 feet by 4 feet. Other parts of the basement have minor cracks should I fill these cracks in and level the area too?
dzobrist is offline   Reply With Quote
Old 01-16-2012, 08:59 PM   #2
DIY staff
Rewards Points: 7,174
First thing--Concrete is what you want--not cement---To fill in a concrete floor regular Sackcrete
mix is fine---compact the gravel---add a poly sheet for a vapor barrier and go to it.
If you are tiling---do not over fill the area and give yourself a high spot---
Post a picture of the cracks---of they are flush (both sides the same height) you should be O.K. to tile.
If they are heaved up tell us--You may need an isolation membrane to make the installation safe---
Old 01-16-2012, 11:06 PM   #3
Rewards Points: 940
If you wanted a curb around your utility room, you should have built, then put the partition walls on it.
Your curb will not stop water.
Elevate the stuff you want to keep dry. Put your furnace and water heater on concrete blocks.
cleveman is offline   Reply With Quote
Tags
basement , cement , concrete , level floor , tile
pouring concrete imogene40 Building & Construction 13 01-16-2012 06:08 PM
Lime, type S/N cement and portland zantar Building & Construction 8 07-11-2010 09:53 PM
cement stairs scotty123 Building & Construction 1 09-15-2009 01:05 PM
Type WL Copper Pipe bathroom slave Plumbing 1 01-26-2009 01:30 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
