-   -   Which type of base for a new shed? (http://www.diychatroom.com/f19/type-base-new-shed-84077/)
Randy2310 10-16-2010 12:26 PM
For my very 1st post I'm looking for some advice on which choice of shed base to build for this shed.
http://www.homedepot.com/webapp/wcs/...61&marketID=15
and this is the type of rock I'm working on. Whoever designed the backyard before my inlaws bought the place decided there should be no grass. The entire backyard not counting the deck & concrete around the pool is that rock.
http://www.glacierwhite.com/images/rock-sqaure.jpg
http://www.wiscopavers.com/images/landscaping_rock.jpg
The instructions give 3 options - solid concrete, wooden structure, or wood frame filled with pea gravel. I would think the pea gravel option is best but I'd like advice from those who have more experience as this is a new project to me. I figured the gravel w/ frame would work because there's already rock, and I would need less gravel if there was already rock within the frame. The gravel would also fill in some of the gap between the rock underneath. The shed floor has drain holes in it
Thanks!
-Randy
Ron6519 10-16-2010 01:56 PM
Some bases trigger tax issues. Sometimes the size of the building does the same. Check it out before you commit.
Ron
jlhaslip 10-16-2010 02:23 PM
Pea gravel is usually 3/8 to 1/4 inch in size.
That looks like bigger than Pea gravel. Might be Texas Pea gravel??? :lol:
Randy2310 10-16-2010 03:19 PM
No the rocks in the picture are same type as the landscape of the backyard. There's NO grass/green. The entire yard is those white rocks. That's why I thought the pea gravel filled base would be the best of 3 because if the wood frame has those rocks inside the border the pea gravel would fill it in the rest of the way and I'd need less gravel
