Tying Area Drain Into Foundation Drain. Bad Ideal? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 12:03 PM   #1
Tying area drain into foundation drain. Bad ideal?
Hello All,
I have a 8 foot retaining wall that ties into the house’s basement on one end and to an outside stairwell at the other end. The wall sits at a 3-4 foot negative grade to the yard. Instead of taking off many dump truck loads of soil I was looking to install an area drain about 10-20 feet out front the bite of the 90 degree angle made from the stair well as it intersects the retaining wall. The house and retaining wall have a foundation drain installed. My question is would it be OK to hook the area drain discharge into the foundation drain?
Thank You
MChief is offline   Reply With Quote
Old 10-13-2012, 07:08 PM   #2
Concrete & Masonry
Rewards Points: 548
I personally think it's terrible idea, especially if the foundation drain leads to a sump pump. In a heavy storm with a power outage, the surface drain is going to put an un-needed load on the foundation.........
jomama45 is offline   Reply With Quote
Old 10-14-2012, 10:40 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
never mix surface/gutter water with foundation drainage, not a good idea. Surface water can add to much flow to the drainage and undermine the foundation...
hand drive is offline   Reply With Quote
Old 10-14-2012, 01:30 PM   #4
Area drain to foundation drain
I thought this to be a bad ideal, just needed to bounce it off a few folks. Now how to redirect the area discharge. I either could drill a hole in the retaining wall or make the discharge run up hill ???
Any thoughts?
Exterior french drain rock and foundation wall care oxicottin Landscaping & Lawn Care 1 08-20-2011 02:25 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 12:07 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
