Two Questions On Setting Trusses - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-18-2009, 04:39 PM   #1
Two questions on setting trusses
I am about to install a new porch on the side of my house this weekend. I have all the trusses modified and all the posts and beams set. I am lost a little bit in two areas, the rest I believe I can handle.
1. How do I fasten the bottom of the trusses to my existing roof? I am building a gable roof off the side of my existing roof and some of the trusses will be on the existing roof. Since the roof is at a pitch, how do I fasten them to the existing. I know I have to put hurricane straps thru the roof and onto the existing trusses, but those don't seem like they are really that strong. I also realize the Plywood will hold it all together better once that is in place. I attached a photo of what I made to kinda have and idea.
2. How do I tie the new shingle into the old shingle at the two valleys I will creat? My dad thinks if I cut the shingles along the valley and slide the new ones up underneath that would do the trick??
**edit: I guess you have to rotate all the pdfs counterclockwise**
GatorsUF83 is offline   Reply With Quote
Old 11-18-2009, 06:19 PM   #2
Registered User
Rewards Points: 4,900
Install the special trusses as per manufacturer's instructions. This may be adding a full length nailer behind the angled bottom chord trusses or special hardware. It is on the paperwork supplied with the trusses.
You remove roofing back from the valley to install valley blocking between trusses, as per plans. Then install ply, metal valley or weave or cut valley shingles after building paper or Grace material.
Be safe, Gary
Gary in WA is online now   Reply With Quote
Building Garage with Engineered Trusses twiles Carpentry 30 03-12-2016 09:17 PM
Pre-Manufactured Trusses or not? my5sons Building & Construction 7 04-13-2012 01:44 PM
Mounting something to trusses bluefitness Building & Construction 1 07-19-2009 07:11 PM
Setting trusses for a Hip roof? TonyGG Building & Construction 13 09-13-2008 09:47 AM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 04:48 PM
