Two Level Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-13-2009, 06:05 PM   #1
Two level deck
Hi all.
I can't figure out how to find any relevant info on this. We have a walk-out basement, so we have an upper and lower deck, right on top of each other. I would like to screen in the lower deck, and be able to use it in the rain. This means I need some sort of roof, above the lower deck and under the floor of the upper deck.
What sort of roof/covering do I need? I guess I could put in an actual plywood/asphalt roof, but this seems overkill, since it will not really be supporting weight of snow or anything. Ideas?
Thanks.
Jeremy
jchansen is offline   Reply With Quote
Old 06-14-2009, 09:16 AM   #2
Rewards Points: 5,336
They have companies that make this product. Just do a search for under deck systems.
Ron
Old 06-14-2009, 10:10 AM   #3
How big is the deck?
How much head room on the lower deck?
There are the wavy plastic panels that many people use as roofs
They are usually 10-16' long
Old 06-14-2009, 03:10 PM   #4
Thanks. Just finding out what it was called allowed me to see a bunch of hits.
Are those plastic panels the ones that look like soffit materials, but without the holes?
Old 06-15-2009, 12:10 AM   #5
you may want to consider "Duradeck" or some sort of waterproof deck for the upper deck. Duradeck is the only one that I know of. It's a vinyl decking kind of like linoleum. It is pricey though.
the carpenter is offline   Reply With Quote
Old 06-15-2009, 08:06 AM   #6
Thanks, all. Even the system at Lowe's looks acceptable.
Jeremy
Building a big deck, just want to make sure its right f8lyer8s Carpentry 14 05-20-2009 12:01 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Ground level deck questions 4just1don Carpentry 7 06-30-2008 08:57 PM
deck level with interior floor, leaking?? Fianna192 Flooring 2 01-30-2008 09:39 AM
Deck footers not 100% level? ssgumby Building & Construction 1 05-11-2005 08:32 PM
