Two Layer Basement?? Plossible On A Budget? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-02-2009, 01:50 AM   #1
Two layer basement?? Plossible on a budget?
Hey guys this is my first post, and i'll try to be straight to the point.
I live in Kansas, I have never owned a home before, and I am mulling over the idea of building a house. I am considering practically all options. "Green" homes, built into the sides of hills, or underground, particularly interest me. On the other hand, I wanted to build a limestone castle at one point. (Just to demonstrate my interests and considerations).
I am overly ambitious at times. I was seriously considering the castle idea, but the limestone and labor would kill me cost wise. I also liked the idea of a deep underground basement, possibly two basements, one on-top of the other. Maybe with a house above that? Why not through some secret passages in with the mix?? lol
Ok well you see my point is, I am very interested in building "something". But I have no experience, and this would be my first home. I want to know if something like "could" be done cheaply. Is it "possible" to do an underground "bunker" like structure, or perhaps even a castle, at a reasonable price (100,000 or less)????. Or is this idea completely out of the realm of possibility? Even if I did the work myself?
Urban_explorer is offline   Reply With Quote
Old 03-02-2009, 05:15 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
that's a tough one, I have clients spend that much on kitchen remodels, I personally can't see it. BOB
Old 03-02-2009, 07:28 AM   #3
Rewards Points: 5,336
All you need is land and a shovel. Should be really cheap. Post pictures when you're done.
Ron
Old 03-02-2009, 07:36 AM   #4
Old School
Willie T's Avatar
The only really important thing to remember about building green is that it also means spending a ton of green.
Depart from conventionality in almost any way, and your costs begin to soar unbelievably. Truly unbeleivably!
Willie T
Old 03-02-2009, 08:01 AM   #5
the Musigician
DangerMouse's Avatar
then again......
http://www.green-trust.org/strawbale.htm
DM
Old 03-02-2009, 08:26 AM   #6
Old School
Willie T's Avatar
Ouch! That's frightening. I notice the boy is from Canada. Not too many places here in the lower 48 you could get away with that.
Here in Florida, it's not uncommon to have $20,000 to $30,000 in nothing but code compliance components and labor to install them. And in high-end homes that cost escalates dramatically.
Willie T
Old 03-02-2009, 09:46 AM   #7
Rewards Points: 1,910
Buy one of those old underground missle sites out in Kansas. You'd have a really nice deep huge basement. Finish out new areas as you need the space. It's already been done by a few folks.
Old 03-02-2009, 12:09 PM   #8
kemerick's Avatar
Rewards Points: 87
Anything is possible, however if this is done to code and safe, it is hard to believe it would only cost $100k.
My constant project is my home, my play time is usually spent on my CNC router.
kemerick is offline   Reply With Quote
Old 03-02-2009, 12:49 PM   #9
Dorothy approves underground as being safer
Land is what may cost you $$ depending upon location
I've have seen an underground structure built out mid-west that was along the lines of what you are thinking of
Not sure what the cost was
Old 03-02-2009, 12:58 PM   #10
the Musigician
then there's the guy selling his house-built-in-a-cave on e-bay..... starting bid is i think 300,000
DM
Old 03-03-2009, 07:25 AM   #11
You know, I actually considered this? I did some reading on those silos you speak of, I actually want to go out and visit this old abandoned one sometime. Its only about an hour and a half from here. The ones that are in livable condition, and are for sale, go for millions. At least the ones I looked at. The lowest one I saw was in the hundred thousands, and it was flooded, and the entrance collapsed.
Old 03-03-2009, 10:23 AM   #12
If you're a realtor you call that a "Fixer Upper in need of a little TLC"
They use to be very cheap.
Old 03-03-2009, 06:47 PM   #13
Rewards Points: 162
It's a noble idea, but remember that unless you live in it forever, you need to consider resale. Building a dungeon tends to limit your market a little bit. Also, you won't get too far on $100k. The deeper you go with a basement, the more expensive it gets. The walls will have a lot more soil pressure which will require thicker walls with more reinforcing. Code would probably prohibit bedrooms below grade unless you had egress windows and a minimum percentage of natural light.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 12:21 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 04:29 PM
