Old 04-30-2008, 08:46 AM   #1
Question
two easy bathroom drywall questions
1. for the ceiling, green rock or regular ?
2. if tile goes only up to a certain height on the walls, i.e. not all the way up to the ceiling, and assuming that it is not possible (or feasible) to be aligning cement board level exactly with that height, should the cement board go slightly OVER or slightly BELOW the tile line ? in other words, should the tile top line be immediately running over cement board or green rock ?
thanks,
- a -
Old 04-30-2008, 08:56 AM   #2
Moderator
Termite's Avatar
1) Never hurts to use the green stuff. I'm not convinced it will make a difference, but with all the humidity in a bath, why not?
2) Hide the transition between the wonderboard and the sheetrock just below the top of the uppermost tile. That way you're not pulling hair out trying to hide that joint. Just keep the joint an inch or two below the top. Tape the joint and "mud" it using mesh tape and thinset.
Old 04-30-2008, 10:17 AM   #3
Exclamation
thanks dude.
Bathroom Drywall jeepwillies Drywall & Plaster 11 05-03-2011 01:04 PM
drywalling bathroom / paperless drywall johnny331 Remodeling 7 10-17-2007 09:06 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Bathroom Drywall Questions Riddler Building & Construction 6 06-27-2006 11:36 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
