Two Curious Questions,Just Trying To Understand - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2012, 09:45 AM   #1
TRV
Two Curious Questions,Just Trying to Understand
Two curious questions 1) I've read where some 6x6 post are buried 2'-3' deep are you pouring concrete around them for lateral support or would it better to use 3/4 " rock for lateral support and to keep the soil and water from contacting the post.
My second question, When notching a 6x6 post for a beam is the weight load distributed equally ? I would think the weight load would only be that section under the notch and not the entire post.
Thanks For The Replies.
TRV is offline   Reply With Quote
Old 06-28-2012, 10:31 AM   #2
AGWhitehouse's Avatar
I wouldn't bury the post or notch it. I would set the post on a concrete pier using these:
http://images.meredith.com/diy/image...SCD_092_07.jpg
And put the beam on top of the post by using these:
http://tamlyn.com/images/products/postcap1.jpg
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 06-28-2012, 11:13 AM   #3
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
If you bury, you must dig past the frost line for the bottom of the hole. You then put in a layer of stone for drainage before you set the post and use the post to compact the stone.
From there you can pour concrete or use lime screenings, tamped in layers. I did the latter for 4x4 PT posts I installed 25 years ago and they are still holding strong with no signs of decay.
A lot of installers use Simpson brackets, as noted in the above post. It's just a matter of choice.
As far as joints, post and beam construction is as strong as it is because of the joints they use, mostly dado and mortise and tenon joints. They add to structural strength when made properly and they are more pleasing to the eye.
Up close is a hammer beam joint but in the background you can see notched beams which are either dados or mortise and tenons with dowel pins inserted for strength. Notice the braces. They are very important in increasing structural strength and rigidity.
Of course, creating the proper joints takes time and patience. Having the right tools and knowing how to do it helps reduce the time. Simpson brackets are much easier but, if exposed, take away from the overall look.
JulieMor is offline   Reply With Quote
The Following User Says Thank You to JulieMor For This Useful Post:
mae-ling (06-28-2012)
Trying to Understand 240v wire selection Bama Electrical 3 05-24-2009 09:36 AM
Ruud Service Manual, Pros don't want me to understand my system Ruuduser HVAC 56 03-29-2009 06:45 PM
Need Help - Dont Understand - CONFUSED mimimaw HVAC 2 08-13-2008 04:03 PM
Pulling Hair Out Trying to Understand NEC on Sub-Panel porschedude996T Electrical 11 10-28-2007 01:28 PM
Help Me Understand! neilyboy Electrical 2 08-13-2006 08:00 PM
