Twenty Four Inches On Center Framing - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-25-2013, 09:35 AM   #16
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
And how do you sell someone on cheapness? Convince them that you can get more insulation in the walls.....
About the only advantage I can see to 24" spacing is the reduced thermal bridging....which...can also be solved with exterior insulation...
Surprised no one brought up Radon....
Old 06-25-2013, 09:42 AM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 820
Well, now that you mentioned it- the builder I referred to did have a radon package in his homes....
Old 06-25-2013, 09:53 AM   #18
JOATMON
ddawg16's Avatar
One of the guys I work with has a degree in environmental cleanup....he worked in CO for several years on EPA cleanup projects.
Radon is one of the biggest scams going. Unless your in the radiation belt (that line that passes from Canada down through IL and into the lower mountains....you don't have a radon problem.
Best way to fix it? You put a plastic layer between the foundation and the ground with small ventilation fans....and you just suck out the air that 'might' contain radon.
Old 06-27-2013, 11:42 PM   #19
Registered User
Rewards Points: 526
Chart R-602.3(5); http://publicecodes.cyberregs.com/ic...9_6_sec002.htm
Wood is a lousy insulator; http://www.buildingscience.com/docum...ure-of-framing
With 1"XPS you would still have only R-9.38 (R-20 in cavity) at the extra studs times how many per building... some arguments met; http://books.google.com/books?id=LR4...raming&f=false
Average 33% less labor/material cost; http://books.google.com/books?id=9wk...raming&f=false
25% of the total wall R-value is lost with standard (16") framing, pp.20, if going high-R; http://www.buildingscience.com/docum...-climate-zones
Gary
Space between mounted TV and entertainment Center BeaglesBuddy Interior Decorating 3 05-31-2011 11:09 AM
Illustrated nailing schedule? cortell Building & Construction 6 11-29-2010 09:26 PM
Entainment center - ceiling differs 1.25" inches side to side - what to do? vsheetz Remodeling 20 12-27-2009 07:46 PM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 02:56 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
