Twenty Four Inches On Center Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-24-2013, 12:15 PM   #1
Rewards Points: 251
Twenty four inches on center framing
I'm working with a contractor in South Carolina who has asked me to consider 24 inch on center framing with 2 x 6 studs & roof trusses. The goal being to reduce framing material costs & labor while gaining a lot of R value in the insulation. I understand a little about value engineering & the reduction in materials while increasing the building's performance. But I also see other issues with this construction like wavey walls, higher risks in hanging heavy items like cabinets on 24" centers, limitations of vynal siding due to stud spaceing, use of sheet rock corner clips & not nailed, crazy nailing patterns, etc.
Most of all if the framer has no understanding of the engineering principles behind this kind of construction, I could be in a world of structural problems. Twenty four inch on center requires very precise alignment of framing members from the trusses on down to the foundation wall. I also am not comfortable with the single top plates & the reduced corner studs.
Also no one is addressing the horizontal load conditions from wind hitting a building at 40 mph plus. Are all these issue just my worry over nothing? Is this worth the savings in materials & labor? I see maybe a material savings of $ 1,500 max on this 2,300 sq.ft. single family home. Labor savings of maybe 3% overall if that. The best thing is the added R value of the insulation in a very hot climate down here in SC. But the unanswered questions of wall loads & strength of the building are a concern to me. Anyone have any experience with this. And lastly, this would be the first 24 inch on center home my contractor would be building. That worries me a lot too going to construction with a GC having no practical experience in the 24" on center construction. Thanks for your input.
Maddog1
maddog1 is offline   Reply With Quote
Old 06-24-2013, 12:32 PM   #2
Old School
Willie T's Avatar
Hey, I'm with you all the way, MadDog.
Willie T
The Following 3 Users Say Thank You to Willie T For This Useful Post:
CENTERLINE MV (06-24-2013), MTN REMODEL LLC (06-25-2013), oh'mike (06-25-2013)
Old 06-24-2013, 12:45 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,172
I think you have a pretty good grasp on the situation.
I'm a big fan of 2x6 lumber for walls. I did my garage that way and was very happy with how much straighter the walls are. On some of the 2x4 walls on my 2-story addition, I was having to reject studs because they were not straight enough. It's just a lot less issue with 2x6 IMO.
Now, with that said...2x4 is fine for walls...16" OC or closer. But 24" OC? Yuk....even with 2x6's...I wouldn't do it. I personally don't think there will be any labor savings....your going to spend more time making sure they are perfect. And if one is off....your potential waste is a lot higher. It's one thing to have to chop off 15" of drywall because the sheet comes up short...but 23"?
Then add in what happens 10 years from now....if you sell the house the next guy is going to come along and start looking for studs to be 16" OC.
And....at 24" OC for walls, your most likely going to have to use 5/8" drywall for the walls....1/2" would be too flexible....
In a nut shell...I totally agree with your position...2x6" on 16" OC....
I'm thinking you might want to find another guy....
ddawg16 is online now   Reply With Quote
Old 06-24-2013, 01:55 PM   #4
Rewards Points: 3,130
For a garage, maybe. For a house, not something I'd do.
Old 06-24-2013, 06:28 PM   #5
Rewards Points: 251
Thanks to all the advice & opinions.
I thin 24" O.C. is too new in the field & an unknown risk.
Maddog1
Old 06-24-2013, 06:33 PM   #6
JOATMON
ddawg16's Avatar
Actually....I think it's old school...it was tried and had too many issues.
The Following User Says Thank You to ddawg16 For This Useful Post:
maddog1 (06-24-2013)
Old 06-24-2013, 06:35 PM   #7
Old School
Willie T's Avatar
Yeah, 24" centers was around 40 years ago.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
Old 06-24-2013, 09:31 PM   #8
General Contractor
CENTERLINE MV's Avatar
Maddog1
Sounds like you know more than your GC does send him over to Contractor Talk and maybe we can teach him a thing or two about a thing or two.
CENTERLINE MV is offline   Reply With Quote
Old 06-24-2013, 09:40 PM   #9
Roofmaster
Rewards Points: 2,172
Simply stated, you do not gain enough in savings to offset the loss of quality.
Forget it, go with a less expensive counter top
Old 06-24-2013, 11:02 PM   #10
Rewards Points: 258
I thought code doesn't allow for 24 on center on exterior walls?
redman88 is offline   Reply With Quote
Old 06-25-2013, 12:57 AM   #11
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
Code does allow for 24" o.c. spacing.
It is somewhat more restrictive though for wall bracing, and many other things but it is doable.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following 3 Users Say Thank You to AndyGump For This Useful Post:
ddawg16 (06-25-2013), maddog1 (06-25-2013), oh'mike (06-25-2013)
Old 06-25-2013, 09:54 AM   #12
JOATMON
ddawg16's Avatar
One other point....on another forum I'm on dedicated to just garages...there are way too many guys dealing with the negative issues of 24" OC. Most common with pole barns. It's harder to hang drywall....you have to put up extra backing for cabinets....walls are wavy....
Insulation.....
Just not worth it....
Old 06-25-2013, 10:21 AM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 452
We have a builder here that does 24" framing. He's a real stickler for energy homes. He builds to those special "green" specs- I can't remember the programs name.
Another builder here does interior walls only at 24"
A lot of commercial projects I've been on- the interior non bearing walls are 24" steel studs with 5/8 drywall
Old 06-25-2013, 10:25 AM   #14
Old School
Willie T's Avatar
I still think that, mostly, it's really just cheapness.
Willie T
Old 06-25-2013, 10:30 AM   #15
Plumber
Rewards Points: 452
Of course it is- The home building market is full of "contractors" in every trade looking for shortcuts.
Space between mounted TV and entertainment Center BeaglesBuddy Interior Decorating 3 05-31-2011 12:09 PM
Illustrated nailing schedule? cortell Building & Construction 6 11-29-2010 10:26 PM
Entainment center - ceiling differs 1.25" inches side to side - what to do? vsheetz Remodeling 20 12-27-2009 08:46 PM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 03:56 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
