TV above fireplace? Would you do it again?
If you've read some of my other posts you know that I'm currently considering mounting an LCD TV above the fireplace in a new home that we have under construction. Since I've never done this before and I really don't know what to expect in terms of ease of view-ability, I'd like to find out how many people who currently have TVs above their fireplace would mount it there again given the opportunity.
The room that I'm mounting this in is 21 x 21', so theoretically we will be some distance away from the TV, which should help with the neck strain issue. |
Oops! Last option should have been "Here's what I would do." Sorry.
Have the fireplace and also thought of doing it to save space since it's so flat. BUT, no way, just to high off the ground to view long term. Works fine in a sports bar setting. Not at home IMHO. Good luck.
Seem like every new house I work on is designed to have the TV above the fireplace
I'd say it depends on how often you use it, how high it would be, and how far back the seating is.
If you watched movies or long periods of TV I wouldn't do it. If the extent of it's use was you watch 15 minutes of news every day it would be fine to put it up there out of the way. How high is your fireplace? I've seen fireplaces you could literally walk into and fireplaces only a couple feet high. You're probably somewhere inbetween. How far back is the seating? The further back the seating the less of a differance it makes. Do you use the fireplace? It would be very distracting to try and watch TV with a fire going right below it. My advice to you, go sit on your couch and stare above the fireplace for a few minutes. The question should answer itself. |
I'd just like to thank everyone for their posts. We have decided NOT to install the TV above the fireplace primarily for two reasons.
1. It would make viewing the TV uncomfortable 2. It would ruin the stone Kelly |
| All times are GMT -4. The time now is 12:20 AM. |
