Turning A Window Into A Doorway - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 08:26 PM   #16
Concrete & Masonry
Rewards Points: 582
If you plan on sawing the brick/block, plan on covering the cuts with some additional material, as the brick/block and joints aren't going to look anything like the rest of the jambs. 95% of the time we "tooth" the brick out on each side and relay them. I wouldn't consider doing this with anything but a 14" concrete/cut-off saw. The problem is that it takes some experience to control a saw of this size in the horizontal position for long stretches, especially without wrecking the rest of the wall. It's not easy to "tooth" these in, but it's often the only way to make it match the rest of the house.............
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
hand drive (04-13-2013)
Old 04-13-2013, 07:39 AM   #17
AHH, SPANS!!!
Rewards Points: 1,166
thanks jomama45 for bringing that up. I was going to mention to the OP that the cut brick will look bad if left as the opening and our Masons always tooth it in which takes a long time but is the correct way to do it.
hand drive is offline   Reply With Quote
Old 04-13-2013, 08:24 AM   #18
Sorry for my ignorance on this... not my thread, but I am wondering...
Can you explain the part in bold? I am really interested in what that means exactly. I am thinking you are saying that they remove more brick in a tooth pattern and then redo the brick so that where you cut ends up as uncut bricks on the edges?
oldhouseguy is offline   Reply With Quote
Old 04-13-2013, 10:37 AM   #19
Concrete & Masonry
Rewards Points: 582
Yes, that's what I mean, we remove the brick back to a full brick, staggered and relay with finished ends.
The 5% I mentioned where we don't typically have to do this is when the brick are solid and/or are getting painted to match the rest of the wall. Even in these remote cases, we still need to grind out & repair the side of the joint at the jamb to it's full and matches the style of the rest of the surrounding veneer.
Old 04-13-2013, 04:18 PM   #20
That's why you are a pro at this!
When I did mine, I cut both sides of the brick flush, extended the jamb out level with the brick, and built a trim column on each side to cover my cuts. Because I was doing an entry way where there was a window, I felt like it didn't need to match the rest of the house. I wanted it to look a bit more "grand", if that makes sense.
I did this a few years ago and if I had to do what you guys do, I would still be working on it.
Thanks for clarifying, I kinda thought that's how it should be done.
Slanted window - should I correct? miamicuse Windows and Doors 11 04-16-2013 06:59 AM
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 08:41 AM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 09:30 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
