Turning A Half Wall Into A Full Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-03-2013, 09:26 AM   #1
turning a half wall into a full wall
i have a basement wall that has a shelf approx 40"off the floor. I am trying to remove the shelf and extend the wall straight up (8' ceiling), there is a flat board under the shelf (might be 1" x 8"), can i build the remaining studs straight up from there with a base plate attached to the 1x8 and ceiling plate at the top?
Mark Windt is offline   Reply With Quote
Old 04-03-2013, 12:31 PM   #2
Maryland
How long is the wall? If it were me, I'd just remove whats there and frame the new wall from scratch. Not going to be that much more expensive.
Take a picture of the existing wall/area and post it. Will help you in getting more suggestions.
Pittsville is offline   Reply With Quote
Old 04-03-2013, 01:52 PM   #3
Roofmaster
Rewards Points: 2,210
This makes no sense. So No, you cant.
Old 04-03-2013, 02:37 PM   #4
"You can do anything"-Mom
brockmiera's Avatar
I just did a project like this in my parents basement last weekend. Snap a picture and post it. I'm sure we can walk you thru the right way to do this.
brockmiera is offline   Reply With Quote
Old 04-03-2013, 03:10 PM   #5
Bill Kearney
Rewards Points: 1,174
Well, you "could" but it'd probably be a bad plan. For one you're not going to get the same structural rigidity as a full wall. Were anyone to lean against it they'd likely cause it to flex and that'll crack drywall. 2x4's are relatively cheap, just build the wall whole. The job will likely go much faster.
wkearney99 is offline   Reply With Quote
Do you two half studs make a full stud? hankbeasley Building & Construction 16 02-15-2013 03:48 PM
Vapour Barrier - Full Wrap OR 1 Piece Per Wall Dreams Insulation 3 01-27-2012 11:12 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
