Turning Concrete-slab Porch Into Mudroom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-25-2015, 09:51 AM   #1
Rewards Points: 248
turning concrete-slab porch into mudroom
Our porch has a concrete slab (with flagstones, but there's an apron of clear concrete around the slab perimeter). The porch is open on two sides as in the attached sketch (sorry for its crudeness; it's not to scale, and I haven't taken the time to learn SketchUp except for some rudimentary stuff).
There is already a roof sitting on three decorative wrought-iron pillars at front left, front right, and rear-right corners. The roof and wrought-iron supports are not shown.
I'd like to enclose the porch, and make it into a sort of mudroom/buffer-zone so that we don't loose so much heat when the door is opened. In general, what kind of things do I need to do to make the walls water-tight?
Can the sole plate be anchored directly to the concrete slab and the studs directly against the brick, or is some sort of water or vapor barrier needed between them?
diy888 is offline   Reply With Quote
Old 11-26-2015, 11:45 PM   #2
Rewards Points: 1,036
you would use sill seal be sure to use pressure treated lumber against the concrete and brick
http://www.acehardware.com/product/i...la=pla_8186163
Mingledtrash is offline   Reply With Quote
Old 11-27-2015, 05:21 AM   #3
Rewards Points: 248
Thanks for that info and link.
House addition over existing concrete porch slab Hardwood Head Building & Construction 10 10-23-2012 07:46 AM
Plans for Retrofitting Concrete Porch - Advice? BSponz1 Concrete, Stone & Masonry 1 05-07-2012 08:35 PM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 02:45 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
