Turn 1 Car Garage Into A 2 Car - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-19-2013, 10:21 AM   #1
bryanp22's Avatar
Rewards Points: 288
Turn 1 car garage into a 2 car
Is it possible to take a 1car garage and extend it into a 2 car? My garage is current 16 feet wide and has a 10 foot garage door. I would be paying someone to do this but I just looking for advice if I should ask to extend the existing structure built in the 50s or just build new.
bryanp22 is offline   Reply With Quote
The Following User Says Thank You to bryanp22 For This Useful Post:
spotts1965 (11-16-2014)
Old 01-19-2013, 10:23 AM   #2
joed's Avatar
Rewards Points: 11,990
Anything is possible. This does not sound that difficult.
Old 01-19-2013, 10:26 AM   #3
bryanp22's Avatar
Rewards Points: 288
Would this be cheaper that building a completely new structure?
Old 01-19-2013, 10:31 AM   #4
Civil Engineer
Rewards Points: 4,566
You cannot realistically expect an internet chat forum to evaluate the cost of expanding an existing garage versus building new. You have provided no photos, not description of the existing garage etc. And this forum generally stays away from cost estimating because costs vary regionally and by the job.
My suggestion is you develop two alternate plans, one for expansion, one for a new building. If you are uncomfortable developing your own plans, you may want to purchase a basic building book such as ones commonly found in big box stores, they often have detailed schematic plans for a garage. Or you can go to a lumber store and purchase a set of detailed plans for a garage.
Then you can bid the job out with two options, one to expand the existing garage, and the other to tear down the existing structure and build new. After you receive a few bids, you will be in a better position to evaluate which way to go.
Old 01-19-2013, 10:33 AM   #5
Rewards Points: 13,270
Got a picture?
What type siding do you have?
The whole roof would have to be removed and replaced or you'll end up with a goofy looking roof line.
Old 01-19-2013, 10:41 AM   #6
bryanp22's Avatar
Rewards Points: 288
I can take some pictures. Do you need just a picture of the outside or the internal structure? I figured the roof line would need to redone. I really was just trying to figure out if enlarging the existing structure was even worth getting estimates.
Old 01-19-2013, 10:50 AM   #7
Only one way to find out, start making some local calls and get some quotes.
Old 01-19-2013, 11:33 AM   #8
DIY staff
Rewards Points: 7,174
There will be a major difference between expanding a free standing garage and an attached one--
Full ,below frost ,footings and stem wall will be needed if the garage is attached to the house---so the more information the better
Old 01-19-2013, 03:12 PM   #9
bryanp22's Avatar
Rewards Points: 288
Here are pictures.
Turn 1 car garage into a 2 car-image-2440937360.jpg   Turn 1 car garage into a 2 car-image-2633118671.jpg
Old 01-19-2013, 04:23 PM   #10
DIY staff
We need an outside shot ans info--is this attached to the house or free standing?
Old 01-19-2013, 04:23 PM   #11
Need one of the outside to see the whole garage.
A close up like that of the inside is useless.
Old 01-19-2013, 05:34 PM   #12
Registered User
Rewards Points: 5,212
It tells us no second story above portion pictured...no trusses on existing, board sheathing on roof, walls sheathed with Thermo-ply, 1/4" foil-faced structural with 1x4 wood let-ins, has a newer vinyl-covered insulated overhead door to reuse (professionally installed with opener), uses a electric weed-eater (green), exercises w. bicycle (healthy, unlike mine w. layers of dust), has 65,543 miles on odometer (just kidding, seeing if you are reading it all) and he shouldn't store material on the rafter ties as they are sagging.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
AndyGump (01-19-2013)
Old 01-19-2013, 05:36 PM   #13
DIY staff
Elementary my dear Watson---
Old 01-19-2013, 06:15 PM   #14
bryanp22's Avatar
Rewards Points: 288
Sorry I thought I included an outside picture. Here it is.
Old 01-19-2013, 08:03 PM   #15
DIY staff
It might be cheaper to simply remove that structure ans build new---
all that will remain of that is one and a half walls---that are sitting on to small of a slab---
Start your price search with a garage building service if you have one in your area---
They can give you a starting price very quickly so you can decide if your project fits the budget--
Saving part of that structure would cost more than tearing it down if I were doing that job--
joecaption (01-19-2013)
breaker box wiring to garage jrhodes1016 Electrical 1 09-30-2012 05:47 AM
how to turn a 2 car garage into a master bedroom suite Convict3 Remodeling 17 08-29-2012 11:35 AM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 08:54 AM
Wiring Garage Sconces paredown Electrical 1 03-28-2012 04:08 PM
Garage floor Tomperro Flooring 6 07-18-2011 01:30 AM
