Old 09-04-2010, 08:18 AM   #1
tuck point a inside decaying chimney base
My chimney is spalling at the bottom. It runs straight through the middle of the house which is three story's high not counting the basement. I have done brick work in the past for a living.The chimney has been rapped with parsing some time in the past by someone.It cracked and that is how i discovered it. It is mainly on one side,but the other side is not too bad.The bad side is spalling up to about thirty inches. I want to tuck point it,but am not sure how much i can take out at one time without it collapsing.The rest of the chimney is like in new condition.I am sure i need to use type n mortar.Please if any one out there can give me advice on this it would be greatly appreciated. Thank you in advance.I forgot to mention I looked inside the chimney and it looks like the inner wall is in good shape. Thanks again.
Last edited by ezj001; 09-04-2010 at 08:38 AM. Reason: I forgot to mention an important factor of the question
ezj001 is offline   Reply With Quote
Old 09-04-2010, 11:40 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
If it is getting as bad as you are stating, it may be better to rebuild, since once you start replacing the bad brick work, you tend to open a huge can of worms.
Old 09-04-2010, 11:49 AM   #3
concretemasonry's Avatar
ez -
Posting your location a little specifically would help, especially if the problem could be related to the climate and conditions.
How old it the chimney?
Tuck pointing materials must be compatible with existing materials and it is really cosmetic or for weather protection and not structural.
Dick
concretemasonry is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Roof leak around my chimney - update GlennAble Roofing 3 11-05-2009 07:24 PM
Chimney leaking and flooding viper9092 General Discussion 2 07-25-2008 06:34 PM
Sweating windows big daddy-o General Discussion 15 01-06-2008 03:41 PM
