Trying To Remove Cement Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 07:05 PM   #1
Trying to remove cement deck
I have just purchased a home that has a 17' x 6' porch addon that is 3' off ground the floor is made from a 6' slab of cement that is attaced to the house with 8 long bolts running from cement and drilled through the wall and sitting on the top of basement wall, the floor is cracked in 4 spots from edge to edgeon of the bolts puuled out when i pulled on it, there is also 4 cement post on the outer edge, my question is what is the safest way to remove this floor ? Thanks.
hoodler is offline   Reply With Quote
Old 06-10-2012, 07:21 PM   #2
DIY staff
Rewards Points: 7,174
Pictures will be needed----
You will want to build stacked 'cribbing' to support the slab while you cut/break it into manageable sized chunks---
You have some serious weight 3 feet off the ground--enough to damage the house or --you!---
Post pictures if you can--otherwise--a better description would help--Mike---
Old 06-11-2012, 09:43 AM   #3
Architect
Rewards Points: 150
Agreed. The construction sounds unique and significant enough to require photos to figure out how to take it down.
jcarlilesiu is offline   Reply With Quote
TREX decking extremely disappointing KHL General DIY Discussions 266 07-05-2013 11:26 AM
Best way to remove deck rail Ranger1227 Carpentry 2 05-19-2011 10:45 AM
How do I remove thinset from cement board? Leoskee General DIY Discussions 14 10-03-2010 08:52 PM
How to remove cement from old tiles guzzigc Kitchen & Bath Remodeling 2 01-15-2009 07:49 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
