Trying To Demo Thick Plaster Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 08:16 AM   #1
Trying to Demo Thick Plaster Walls
A friend of mine has Thick plaster walls and he wants to demo them in order to expand his kitchen.
His question is he wants to know the best method to take it down while avoiding the old sledgehammer approach.
Are there any heavy duty saws or tricks when dealing with heavy plaster walls, or something better that are able to perform this type of demo?
Any advice would be greatly appreciated.
Thanks!
earthad1 is offline   Reply With Quote
Old 03-28-2011, 08:29 AM   #2
Rewards Points: 5,336
The easiest is with a hammer, using it in a controlled way. This can be achieved if the plaster is over perforated plaster lath. These are panels nailed to the wall where the brown and top coats are applied. You make a series of horizontal hammer holes along the wall. Every 32" or so,make vertical holes down the hall. The panels can now be pulled off the walls in manageable sizes.
If you have wood lath underneath, I would take it off in stages. Start from the bottom and hammer the wall. The keys will break off and the wall material will fall to the ground. After all the plaster is off, remove the lath.
Close the room and wear masks, gloves and glasses.
Have a first aid kit handy, for you will bleed.
At the ceiling and wall turns, you might find metal lath. This stuff will cut through leaher gloves, so be careful.
Ron
Old 03-28-2011, 08:42 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Sawzall with a plaster cutting blade..............
tcleve4911 is offline   Reply With Quote
Old 03-28-2011, 09:43 AM   #4
I've relayed the info to him.
Thanks for the help guys.
Plaster Walls? I dont know? chsitko Drywall & Plaster 4 08-28-2010 05:30 PM
Plaster walls that sweat minus General DIY Discussions 3 07-04-2010 12:20 PM
mounting things on lath and plaster walls wilderstyle General DIY Discussions 11 01-17-2010 08:48 AM
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 03:42 PM
Fishing through plaster and lath walls?? slatergrl Electrical 7 02-05-2008 08:29 AM
