The Truth About Load Bearing Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 04:04 PM   #1
The truth about load bearing walls
OK, I have a wall between my livingroom and kitchen it has a swinging door...the house was built in 1938 and has had no remodeling..I want to take down the wall with the door, the wall is only 8ft, with no electric or plumbing running in it...is it true that if the rafters in the attic run parallel with the wall and there is no header over the door, that it's NOT a weight bearing wall?
910Kayaker2 is offline   Reply With Quote
Old 02-06-2011, 04:12 PM   #2
Framing Contractor
No, it's not true.There could be ceiling joists on top of that wall and someone didn't put a header in. Ceiling joists and rafters don't always run the same direction. Go in your attic and see what's above the wall.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
oh'mike (02-06-2011)
Old 02-06-2011, 08:23 PM   #3
Load bearing wall
Thanks Joe, I had seen something about that online, thats why I figured I'd ask on here, the more info the better! Thanks again!
determining opening in load bearing wall RonGage Carpentry 0 11-05-2010 09:24 AM
Removing a load bearing wall, adding a beam ? Lakedriven Building & Construction 9 11-02-2010 07:12 AM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 04:25 PM
Load Bearing Exterior wall however it has an overhanging porch rhoton1 Building & Construction 2 03-16-2009 06:19 PM
Roof Sag/No Load Bearing Interior walls mrkleyn Roofing/Siding 1 08-13-2007 10:00 PM
