Truss Style Roof And Load Bearing Walls? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-28-2012, 08:24 AM   #1
Rewards Points: 219
Truss style roof and load bearing walls?
Is it true that with truss style roofs, my interior walls should not be load bearing?
Our huge master bedroom has no "load bearing" walls so I am sure the couple of small walls in the master bedroom/closet are not load bearing, but am wanting to make sure!
bassadict69 is offline   Reply With Quote
Old 04-28-2012, 08:52 AM   #2
Framing Contractor
Rewards Points: 120
Trusses can often bear on interior walls. Most simple trusses bear only on the exterior walls. We have no way of guessing without at least some pics.
sixeightten is offline   Reply With Quote
Old 04-28-2012, 09:17 AM   #3
Civil Engineer
Rewards Points: 4,854
Your post is pretty confusing. "Is it true that with load bearing walls, my interior walls should not be load bearing?"
I really don't know what you mean, maybe you can rewrite this to make more sense.
Old 04-28-2012, 09:21 AM   #4
Rewards Points: 219
Oops! It has been fixed...
Also, I will shoot some pics later and post them up!
Old 04-28-2012, 08:25 PM   #5
Rewards Points: 219
Here are a few pics of the walls I am wanting to come down...I have not been able to get up in the attic to take pics of that yet! Hard to tell anything in these pics, but here they are!
Best I could get showing the bedroom and the wall seperating it from the bath room area... This wall is staying!
Basically all the walls I gutted to the studs I want gone...
For some reason, every wall I have stripped sheetrock from in this house had the doubled stud on top...not sure if it means anything or not!
The two door openings went into what was a huge closet. The whole plan is to shrink the closet by walling it off in between where the two doors were, with the wall running to the right in the pic. This will leave everything open from that wall towards the toilet (where this pic is from) If it helps, the trusses in the attic run the same direction as the wall studs shown in this pic.
Old 04-28-2012, 09:52 PM   #6
retired union carpenter
Send a message via Yahoo to coupe
I always consider any wall running perpendicular to the ceiling joists as being a load bearing wall to some degree!
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 04-29-2012, 01:19 PM   #7
Framing Contractor
Rewards Points: 120
Those pics don't tell us anything. Is the roof a straight forward typical gable? Are you sure you have trusses and not rafters? The double top plate is standard procedure in bearing and non bearing walls.
load bearing for flat roof timbo59 Building & Construction 8 06-02-2011 01:36 AM
load bearing walls worriedowner Building & Construction 3 02-02-2011 04:12 PM
load bearing with a hipped roof SickPuppy Roofing/Siding 7 06-04-2008 03:01 PM
Roof Sag/No Load Bearing Interior walls mrkleyn Roofing/Siding 1 08-13-2007 10:00 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
