Truss Spacing For Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-18-2012, 03:48 PM   #1
Rewards Points: 12
Truss Spacing for Shed
I am building a 10x12 shed off of plans from Better Barns. The plans call for 24" o.c. spacing on the trusses. The stud spacing on the side walls (by plan; already built and erected) is as follows (all o.c.): 20-1/4", 25-3/4", 24", 24", 25-3/4", 20-1/4". I guess my question is: is it a problem that the trusses won't be directly over the studs? If it is, what should I do? Thanks.
MrUnderhill is offline   Reply With Quote
Old 07-18-2012, 04:27 PM   #2
Rewards Points: 528
If you have a double top plat, no problem at all.
framer52 is offline   Reply With Quote
Old 07-18-2012, 05:45 PM   #3
Rewards Points: 12
I have a single top plate, guess I should have mentioned that. That's what the plans called for. So now what?
Old 07-18-2012, 06:01 PM   #4
kwikfishron's Avatar
Rewards Points: 344
You can always add another plate.
Why is the stud layout weird like that?
You said it was per the plan but I find that hard to believe.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
framer52 (07-18-2012)
Old 07-18-2012, 07:43 PM   #5
Rewards Points: 12
I have no idea why it is weird. See for youself, though...I attached a photo. I already put the siding on the shed, so do I have any alternatives to putting another top plate on? Can I just reposition the trusses over the studs or is the spacing critical? If I do nothing, will I run into problems? Sorry for all of the questions, I just don't know if this is a big problem. Thanks, again, for the responses
Old 07-18-2012, 11:49 PM   #6
Rewards Points: 2,210
The weird spacing is because of the windows.
mae-ling is offline   Reply With Quote
Old 07-19-2012, 02:14 AM   #7
Rewards Points: 502
Lets consider the figures from an engineering point of view. Assume a worst-case scenario, with your trusses central over each gap (see sketch).
The critical problem will be the maximum bending stress induced in the timber top plate by the point load from the trusses. Assuming your timber has a maximum allowable bending stress of 800lbs/sq.in., then the maximum load from each truss should be no more than approx. 250lbs.
If your shed is 10ft wide. then this would translate to a total allowable load of 25lbs /sq ftwhich is not a high figure.
Anything above this would probably be too much for the top plate. However, because your trusses are nowhere near as offset, the stress will be very much less than the maximum allowable. IMO you will be absolutely fine. [To work out the actual maximum bending moment (and hence the maximum stress) for the offsets you have would be complex and time-consuming, probably requiring a computer, but it would show the stress being well below 800 lbs/sq.in.]
There is a very knowledgable civil/structural engineer on this forum. See if he chips in and I'm sure he will confirm the figures.
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
MrUnderhill (07-19-2012)
Old 07-19-2012, 05:24 AM   #8
Rewards Points: 344
Well, I stand corrected….I see the reason for the odd layout as mae-ling pointed out. I’ve never come across that before since I’ve never put a wood shed kit together before. If I did we’d be running back for some more wood to properly frame in the windows and likely the door too. but that’s me.
For less that $20 you can add another top plate. Not sure if the extra height would affect the siding or not but an extra piece of trim outside could fix that.
It’s just a shed, there’s all kind of things you can do improve the quality of it and make those four walls and roof just as strong as any house but again, “it’s just a shed”.
If you don't want to spend anymore money on it then stick to the plan. What's the roof plan call for?
Old 07-19-2012, 05:35 AM   #9
Rewards Points: 12
The roof has 7 trusses (the two end trusses have gable extensions). The plans say to space them 24" o.c. (although, that won't quite work out). The roof sheathing was supposed to be 1/2" CDX, but I substituted 1/2" OSB. The roof pitch is 10/12. I knew the window framing was wrong, but it called for simple barn sash windows so I figured it was fine. I just assumed the plans were going to call for placing the trusses over the studs, but now that I'm near that point I saw the spacing and started to worry. Thanks for everyone's input, I really do appreciate it.
Old 07-19-2012, 07:26 AM   #10
Rewards Points: 13,444
Double top plates also help to lock the tops of the walls together if there over laping the plate below.
Poor set of plans in my opion.
Gable End Truss Offset Siding ChristianT Carpentry 7 07-29-2011 03:54 PM
Stick Rafter not attached to bottom chord & sagging, new Trusses Robear Roofing/Siding 12 10-16-2009 04:41 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 08:45 PM
2nd story ledger to floor truss fisherk Carpentry 1 10-18-2008 12:08 PM
Gambrel Truss Dormer and Ladder Framing? fauer Carpentry 3 09-30-2007 07:36 PM
