Truss Bracing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-30-2011, 08:08 AM   #1
Truss Bracing
I am erecting a 15'x15; hip truss roof with a 1ft cantilever. I have 5 center trusses that span the entire distance & the rest are hip & jack rafters. I am concerned with adequate temporary bracing. Any suggestions would be appreciated
Mike47ma is offline   Reply With Quote
Old 08-30-2011, 10:06 AM   #2
Too Old
I would stand one center truss and nail it with a brace going to the wall then stack the other four. install the hip & jack on 1 side then remove the brace and stack the other side.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 08-30-2011, 06:01 PM   #3
I lay the hip girder flat, nail in the mono jacks, tip it all up as one unit, that truss is now completely tied off and I can raise the next and block or brace it to the girder. Easy
Ninjaframer is offline   Reply With Quote
Gable End Truss Offset Siding ChristianT Carpentry 7 07-29-2011 03:54 PM
Shed Roof Truss FKampf Building & Construction 2 05-11-2011 07:46 AM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 08:45 PM
2nd story ledger to floor truss fisherk Carpentry 1 10-18-2008 12:08 PM
Gambrel Truss Dormer and Ladder Framing? fauer Carpentry 3 09-30-2007 07:36 PM
