Troublesome Joist Nails - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-21-2009, 03:21 PM   #1
Beyond using Craftsman's automatic hammer (which is unfortunately on back order), what are some options for driving nails in tight spaces; too tight to swing a hammer? Thanks!
Mr.S Teacher is offline   Reply With Quote
Old 07-21-2009, 03:43 PM   #2
Registered User
Termite's Avatar
Use a palm nailer. Paslode, senco, bostitch, ridgid, hitachi and a lot of other manufacturers make them for around $70. They're used with an air compressor and work as slick as a whistle (and a heck of a lot better than anything battery powered that Craftsman makes).
Old 07-21-2009, 05:05 PM   #3
Civil Engineer
Rewards Points: 4,782
You can also drive structurally rated screws in tight places, especially if you have a right angle drill. Just make sure the screws are rated for the application, and are correctly installed (i.e. you drill the correctly sized pilot hole).
Daniel Holzman is online now   Reply With Quote
Old 07-21-2009, 08:33 PM   #4
Registered User
Rewards Points: 5,516
As KC said: http://search.harborfreight.com/cpis...iler&Submit=Go
Come to Tacoma, Harbor Freight by the Narrows Bridge or a $50, better one a BMC West on South Tacoma Way.
Or a stubby: http://search.harborfreight.com/cpis...mmer&Submit=Go
Be safe, G in Tacoma
Old 07-22-2009, 11:48 PM   #5
Thanks to ALL of you for the quick replies. Those are both options I hadn't thought of, and I'm looking forward to using your advice as I tackle the joists one more time tomorrow.
Tags
joists , nailing , nails
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
floor joist issue drtbk4ever Building & Construction 4 03-22-2009 10:20 AM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
