Tripple 2x10 Beam Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-29-2007, 02:40 PM   #1
tripple 2x10 beam construction
I have 4 posts in a row seperated by 9ft then 11ft and 11ft. By code I will need a triple 2x10. for the 9ft to 11 ft span I can use 20ft long 2x10's however to cover the 2 11ft sections I would need a 2x10x24 which I cannot get. Can I sandwich 2 12 ft long ones with the seam being almost half way over the middle 11ft span? I would bolt everything together?
george514 is offline   Reply With Quote
Old 05-29-2007, 02:47 PM   #2
Rewards Points: 264
How bout a parallam?
Jeekinz is offline   Reply With Quote
Old 05-29-2007, 02:52 PM   #3
The cost differance. A parallam is $37.50 a lineir ft or around $1200.00 compaired to around $200.00
Old 05-29-2007, 03:07 PM   #4
Rewards Points: 264
Shop around http://store.dunnlum.com/builderwire...?categoryid=24
Old 05-29-2007, 03:22 PM   #5
Not easy to find. I need it presure treated. I did find one for $24.91 a linear ft which is more acceptable. I wonder if I need 3.5x11.75 or if I could go smaller because its a composite beam.
Old 05-29-2007, 04:09 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
What you propose to do by sandwiching the beam would work. I would suggest that you use 12' lengths for your design to gain you overall 24' length on the outside layers and place a 20' in the middle layer centered.
As far as bolting it all, you should be able to get by with construction adhesive and 3 1/2" galv. nails on both sides every 12", 4-5 stacked. I hope you plan on using 6x6's for posts.
However, I do not know the exact design specifics, weight loads, etc. for what you are planning to build...thus:
You should run your plan on the beam design and post layout by inspectional services just to make sure that you are good to go.
Example:
- Build Well -
Hanging a beam/rafter from a beam snmhanson Building & Construction 4 01-11-2007 11:37 PM
Floor Support Beam SlipperyPete Building & Construction 3 12-04-2006 06:55 AM
Construction safety nightmare 'Andyman Off Topic 2 09-13-2005 12:20 PM
drilling a support beam sdmotor Building & Construction 1 07-12-2005 11:51 PM
