Old 06-14-2012, 08:28 PM   #1
Trimmed a door
Trimmed down an interior hollow core door. Please see the pic. Should I do anything to reinforce the bottom or will it be ok? It's for a bathroom.
schatzi is offline   Reply With Quote
Old 06-14-2012, 08:30 PM   #2
Super Moderator
Trimmed a door
Yep--you need to add a long block of wood and glue it in---
Some times you can reuse the bottom that you removed,by slicing off the skin with a table saw---
Old 06-14-2012, 09:24 PM   #3
AHH, SPANS!!!
Trimmed a door
yep, you will have to fill in otherwise the bottom of that door will come apart.
hand drive is offline   Reply With Quote
Old 06-14-2012, 09:32 PM   #4
Trimmed a door
Kinda what I figured. Thanks!
The Following User Says Thank You to schatzi For This Useful Post:
oh'mike (06-14-2012)
Old 08-10-2012, 08:55 PM   #5
Trimmed a door
How much did you cut off? Is there a standard measurement of "solid wood" that is in each hollow door bottom and top? I have 2 "hollow" doors that I need to shorten, not sure how much I can cut off before reaching the hollowness.....
Hunter333 is offline   Reply With Quote
Old 08-10-2012, 10:08 PM   #6
Trimmed a door
That spacer at the bottom is an odd ball size, so you have make one out of a 2 X or 2 X 4 on a table saw or often times if you use a sharp razer knife you can peel the skin off the old one and use that.
There is no standard width for that spacer, any more then 1/2 and your in trouble.
Old 08-10-2012, 10:19 PM   #7
Super Moderator
Trimmed a door
Cheaper doors have a one inch tall bottom piece----Better quality maybe 2 1/2 inches---
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 10:27 AM
closet door options bubbler Building & Construction 2 01-09-2012 01:43 PM
Rotten bottom plate and subfloor around exterior door deraj123 Building & Construction 5 08-13-2010 11:43 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
