-   -   Trimmed a door (http://www.diychatroom.com/f19/trimmed-door-147067/)
schatzi 06-14-2012 07:28 PM
Trimmed a door
Trimmed down an interior hollow core door. Please see the pic. Should I do anything to reinforce the bottom or will it be ok? It's for a bathroom.
http://i371.photobucket.com/albums/o...m/392c9664.jpg
oh'mike 06-14-2012 07:30 PM
Yep--you need to add a long block of wood and glue it in---
Some times you can reuse the bottom that you removed,by slicing off the skin with a table saw---
hand drive 06-14-2012 08:24 PM
yep, you will have to fill in otherwise the bottom of that door will come apart.
schatzi 06-14-2012 08:32 PM
Kinda what I figured. Thanks!
Hunter333 08-10-2012 07:55 PM
How much did you cut off? Is there a standard measurement of "solid wood" that is in each hollow door bottom and top? I have 2 "hollow" doors that I need to shorten, not sure how much I can cut off before reaching the hollowness.....
joecaption 08-10-2012 09:08 PM
That spacer at the bottom is an odd ball size, so you have make one out of a 2 X or 2 X 4 on a table saw or often times if you use a sharp razer knife you can peel the skin off the old one and use that.
There is no standard width for that spacer, any more then 1/2 and your in trouble.
oh'mike 08-10-2012 09:19 PM
Cheaper doors have a one inch tall bottom piece----Better quality maybe 2 1/2 inches---
