Trim For Door In Corner? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-22-2009, 11:54 AM   #1
Trim for door in corner?
I am ready to trim out a door in a newly finished room. The door is right in the corner of the room, with only about 2.25 inches between the hinge and the corner. The standard trim I have fits if pressed in firmly, but doesn't allow me to have a proper reveal (it's pressed right up against the hinge). Also, the adjacent wall is slightly bowed, causing a small, but noticeable change in the gap between the trim and the corner. I would have no problem using narrower trim, but I can't find anything smaller at my local stores. The only idea I have is to trim that door using some left over door stop pieces I have laying around. Any other ideas?
raida357 is offline   Reply With Quote
Old 11-22-2009, 12:54 PM   #2
Remodeling Contractor
you simply cut the wide side (outside) of the trim to the space you have available. Scribe the edge you will cut to follow the bow in the wall. you will also need to trim the top corner of the top trim piece. Trimming is easy when the framing is right. Here you are seeing the results of poor planning (door less then 6" to the corner) and bowed wall.. (used a board with a crown or not quality lumber or green lumber) and no one supported the corner to both walls properly to avoid the bowing. Good corners are perfect. Always!
Old 11-22-2009, 01:09 PM   #3
Wouldn't the difference in trim width from one side of the door to the other be noticeable?
And this wall was built by "professionals"!
Old 11-22-2009, 02:53 PM   #4
no by a hack that had the "" to charge someone for that. There is no excuse for any of the conditions you are trying to work on. Anyway the small width difference will not be as noticeable as the door squished into the corner. the trim is only 2 1/2" and you are only trimming a 1/2" of off it. I've had jobs where the door or window trim needed to be only 1" at the corner.
Old 11-22-2009, 02:56 PM   #5
Cool, thanks!
Trim caulking near corner of room RxScram Carpentry 2 09-27-2009 07:18 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
can never get door/window trim to corner nicely. windowguy Carpentry 6 02-21-2009 10:11 AM
Baseboard, How do you trim out a bullnose corner kcdave Carpentry 4 11-24-2008 02:23 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
