tricky drilling
we'd use a diamond core bit for the brick part of the hole THEN our bosch rotating hammer for the conc,,, no sense is having to make addl brick repairs if you can avoid it !
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
