tricky drilling
1 Attachment(s)
hey evry1,
I need to drill a 3/4" hole for a pipe for a camara system im installing at my home its gonna be going through a 12" thick foundation wall into my basment. the problem is its 5" away from a door cutout and 5" away from the steel header (were it ends) is the foundation gonna crack were the steel ends and all the brick its holding up gonna fall on me? |
You should be just fine,----A hole like that will require a good sized hammer drill--they can be rented,some rental places will rent you the bit also.---good luck-have fun---Mike--
I just stocked up on new diamond bits for tile----$40.00 hole is right!
You are fine --If you can go through a morter line your drilling will go faster.
It takes a lot to knock down a brick building. Just go to it and have fun.--Mike-- |
we'd use a diamond core bit for the brick part of the hole THEN our bosch rotating hammer for the conc,,, no sense is having to make addl brick repairs if you can avoid it !
| All times are GMT -4. The time now is 03:14 PM. |
