Trex Post Height - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 06:27 AM   #1
Trex Post Height
Hi, may be a dumb question, but can anyone tell me the necessary height for a deck post when using trex transcend railing system...my posts are 39" high, but when I put the 2x6 decking on, I'm going to lose ~1.5" and I'm now wondering if I cut them too short.
Thanks,
jjw
daacrusher2001 is offline   Reply With Quote
Old 07-14-2010, 01:22 PM   #2
Rewards Points: 5,336
Codes for rails generally run from 36"-42". Check to see what your codes are.
Ron
Old 07-14-2010, 03:26 PM   #3
clarification
Ron
Ahh...I'm asking the question wrong. 36" is the code. But...I was wondering if I cut my posts too short to use with the Trex post sleeves and rails.
It said 39" posts, but when I add the decking I'm going to lose 1.5" so they'll be approximately 37.5" posts...not sure if there is sufficient height to put the railings and post caps in place.
Old 07-14-2010, 06:12 PM   #4
kwikfishron's Avatar
Rewards Points: 344
Your 39” post are setting you up for a 39” finished rail. That’s fine if 39 is what you want.
Personally I wouldn’t cut all my post to length except maybe the corners. Run your post long and string line and cut them off when it’s time to run the cap.
Little discrepancies in the framing and pre-cut post can lead to a roller coaster rail.
kwikfishron is online now   Reply With Quote
Post mounted electrical receptacle NIlRO Electrical 13 04-19-2010 02:20 PM
Trex Decking & Railing Systems Patricia Folsom Building & Construction 11 10-08-2008 09:06 PM
