Trex Decking Installed Over Pressure Treated Wood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 03:04 PM   #1
trex decking installed over pressure treated wood
Can anyone tell me if it is ok to install trex decking over top of pressure treated decking material. I realize it will raise the deck higher by the door but will the wood beneath possibly rot?
leeken54 is offline   Reply With Quote
Old 05-01-2010, 04:56 PM   #2
kwikfishron's Avatar
Rewards Points: 86
Yes it will and I wouldn’t do it. You should remove the old decking deal with any frame issues (if any) and install the Trex.
Trex is spendy stuff and it’s not as easy as you would think to pull up later. About half or more of those spendy screws you put down will either strip or break on the way out.
kwikfishron is offline   Reply With Quote
Old 05-01-2010, 05:54 PM   #3
The wood will rot & the trex will be more prone to fall apart
May also void the Trex installation instructions & thus the warranty
Do a search on this site for Trex & read
Old 05-01-2010, 06:11 PM   #4
Registered User
Rewards Points: 4,912
As said, bad idea..... The Trex NEEDS air circulation underneath to honor the warranty with mold likely growing a bumper crop.
Be safe, Gary
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Pressure treated wood? sharp Building & Construction 5 04-13-2010 08:50 AM
Cracks in pressure treated posts (4x4s, 6x6s) Deck Building & Construction 8 05-15-2008 11:57 PM
Pressure Treated Decking Broncosfan1983 General DIY Discussions 2 09-13-2007 08:12 PM
Pressure treated wood - attracts bees? mcvane Carpentry 4 08-31-2007 09:43 AM
