Trenching Through Granite - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 07:38 AM   #1
Rewards Points: 508
Trenching through granite
I found a couple of spots in a trench I dug for 3" conduit that are encumbered with granite gneiss and blue stone. In a couple of spots the stone presents an angled plane.
My neighbor recommended using a concrete saw to score a channel in the stone for removal with a jackhammer.
I was considering drilling holes with a rotary hammer to use Dexpan expanding mortar.
I was also considering drilling 1-1/2" holes and using the jackhammer to connect the dots.
I need to cut a 12" x ~3.5" channel in the stone. I have the tools and the materials for either job. Would you use any of these methods, or can you recommend another approach?
benjamincall is offline   Reply With Quote
Old 01-31-2012, 07:44 AM   #2
joed's Avatar
Rewards Points: 13,348
What is the conduit for? Can't you just go over the rock and then encase with concrete.
Old 01-31-2012, 07:49 AM   #3
Civil Engineer
Rewards Points: 4,858
I had a similar problem with a 4 inch drain line I installed. The simplest approach is to use a rotary hammer with a diamond bit to drill small holes (say 1/2 inch to 1 inch) relatively close together, then use an impact hammer with a chisel bit to clean between the holes. Diamond drills go into granite very quickly, the chisel part takes a little longer. I wouldn't waste my time with that expanding material, by the time you put it in, wait for the setup and breaking, you could have been long done using standard hammer type tools.
Daniel Holzman is online now   Reply With Quote
Old 01-31-2012, 10:39 AM   #4
Rewards Points: 508
The conduit is for a service lateral. I would try to go over the rock, except that it would create a severe peak in the conduit that I couldn't address without adding more sweeps.
Wouldn't I want to use my 1-1/2" bit to drill the holes, then "connect" the holes using the jackhammer? Would you drill in at an angle to break out a wedge of stone?
Is this a lousy granite installation? timbo59 Kitchen & Bath Remodeling 70 05-16-2013 10:08 PM
Finding a good granite fabricator for kitchen countertop tseverson Kitchen & Bath Remodeling 5 04-20-2012 02:50 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 04:54 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
Granite Hearth/Saltillo tile transtion help SeminoleMike Flooring 2 02-08-2009 11:49 AM
