Treehouse 1/2 Inch Flooring - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 06:59 PM   #1
Question
Treehouse 1/2 inch flooring
im making a tree house, and my floor joists (2x10s) are spaced approx. 16in apart from each other, and i have cross-joists between them like everywhere. Would it be alright, considering my standards, to use 1/2in plywood. its way cheaper than 3/4 at my local supplier, and im goin to need nearly 12 sheets in the end to cover everything.
Bill
Bgm94 is offline   Reply With Quote
Old 07-17-2010, 07:16 PM   #2
Rewards Points: 5,336
That's 384 sq ft of flooring. Did you build this thing in a Sequoia?
This plywood would need to be protected from the weather. You would also need to purchase exterior graded 1/2" plywood.
Ron
Old 07-17-2010, 07:22 PM   #3
kwikfishron's Avatar
Rewards Points: 86
12 sheets to cover the floor, that’s a big tree house.
I have to assume you mean 12 sheets for the floor and walls. Either way don’t skimp on the floors. ¾” on the floors ½” on everything else.
kwikfishron is offline   Reply With Quote
Old 07-17-2010, 07:22 PM   #4
Ron
yeah its actually spread between 4 trees, but we got the budget for the 3/4, thanks anyway though!
will post pics soon if anyones interested
Old 07-17-2010, 07:24 PM   #5
Learning by Doing
Leah Frances's Avatar
yes, post pics!
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-17-2010, 07:42 PM   #6
Smile
Pics
just 3 from today
will post more as progress is made
expect a finished product beginning of Aug.
Back is 20 feet long, sides are 16 (roughly), front is 16
The front extension is a 4'x14' porch
(measurements are from memory, not exact)
also pics are without the cross-supports from joist to joist
Treehouse 1/2 inch flooring-img_8276.jpg   Treehouse 1/2 inch flooring-img_8277.jpg   Treehouse 1/2 inch flooring-img_8282.jpg
Old 07-17-2010, 07:43 PM   #7
DIY staff
Rewards Points: 7,174
Good advice!.
Old 07-17-2010, 07:54 PM   #8
Rewards Points: 86
You look like a up and coming framing star to me.
Hope you have something a little bigger than just nails stuck into those trees.
Old 07-17-2010, 07:55 PM   #9
5 inch galv lags
Old 07-17-2010, 08:03 PM   #10
Rewards Points: 86
Originally Posted by Bgm94 View Post
5 inch galv lags
Good deal, you could get away with ½” if you block the seams,
even just 2x4 blocking. I’m starting to think lets keep the weight down.
Old 07-17-2010, 08:05 PM   #11
yeah dude im a little skeptical at this point.
ANY IDEAS FOR MORE SUPPORT? (without adding supports under the structure)
Old 07-17-2010, 08:16 PM   #12
Rewards Points: 86
You could always build a skateboard ramp to come up under and support the end you’re sitting on.
Old 07-17-2010, 08:23 PM   #13
hahah funny thing is i do skateboard A LOT
Old 07-17-2010, 08:27 PM   #14
the Musigician
DangerMouse's Avatar
I'd have to add here, enjoy it while you can when it's done. It will likely not last long.
The trees are different sizes and species? They will grow at different rates and that floor is going to be wonky soon....
Sorry if I rained on your parade at all.....
DM
Old 07-17-2010, 08:32 PM   #15
Rewards Points: 86
If you’re going to build walls and a roof you really need more support. If you don’t want to look at 4x4 post find a small tree to cut down and make post out of that. At least you’ll have barked post to fit in with the tree thing.
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 12:21 PM
old 3/4 inch oak flooring with dirty traffic area sw8689 Flooring 5 01-11-2010 12:33 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 12:19 PM
Need some "exercise room" ideas. Artie2 Remodeling 10 08-18-2008 12:01 AM
