Treated Lumber - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 10:29 PM   #1
Treated Lumber
I am building a deck!! I am just starting to lay the decking-only 8 12' boards done. On the web sites I have been reading instructions from they say to use a 16d nail to make the gaps between the boards. Two neighbors stopped by and were horrified. They say that the treated lumber is wet and there should not be a gap, I should lay the boards side by side and as the wood dries the gaps will get there on their own. Are they right?
tayna is offline   Reply With Quote
Old 07-14-2011, 10:44 PM   #2
firehawkmph's Avatar
Rewards Points: 1,902
Tanya,
I would have to side with your neighbors. The old 16 penny nail trick was always shown on diy shows and in how to books. I butt the treated lumber up tight. By the time it dries it ends up with 1/8"- 3/16" gaps. If you were using the manmade decking that doesn't shrink, then the 16d nail trick works fine.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 07-14-2011, 10:51 PM   #3
dpach's Avatar
Generally, yes they are correct. But it depends on where you purchased your lumber. Big box stores like HD, Rona's etc tend to go through a lot more and tend to ship it in quick from suppliers. This means it tends to have more moisture in it. I've purchased PT lumber from a good lumber yard and they say it's been aged/dried and after using it, seen very little shrinkage due to drying (but still some shrinkage).
In general, most people using PT for decking do put the boards down just touching each other (not pressed together) and after the moisture dries out from the wood, each piece can shrink by 1/16th to 1/8 inch on each side of the board.
Good luck. Enjoy the build.
dpach is offline   Reply With Quote
Old 07-14-2011, 10:54 PM   #4
yes they are correct , wet lumber will shrink in time and gapping them now would cause bigger gapping later
fulton 22175 is offline   Reply With Quote
Framing Treated Lumber Sbagwell647 Building & Construction 7 07-14-2011 11:04 PM
Shoddy Pressure Treated Lumber? spanky77 Building & Construction 17 06-25-2011 08:09 AM
Treated lumber secutanudu Painting 5 09-11-2010 11:51 AM
Where to buy heat treated Plywood or OSB and lumber? Spud General DIY Discussions 5 10-21-2009 09:49 PM
removing treated lumber edging pacifier1er Landscaping & Lawn Care 3 07-02-2008 12:08 PM
