Treated Decks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-24-2011, 05:38 PM   #1
Treated decks
Is using treated 5/4 decking going to be okay with 16" o.c. 2 x 10 joist with 12 ft span
Joseph79 is offline   Reply With Quote
Old 06-24-2011, 07:15 PM   #2
Rewards Points: 5,336
It will be fine as long as you're installing it perpendicular to the joists. Diagonally installed 5/4" would need 12" on center.
Ron
B. Franklin 1759
Old 06-25-2011, 08:07 AM   #3
Rewards Points: 1,216
OK, if the treated 5/4 is new(green) make sure you butt them tight against one another when screwing them down because you will have shrinkage and you Will end up with a 1/8 to 1/4 inch gap any way. A lot of people will tell you to space the apart don't do it they will shrink and your gap will be unsightly.
COLDIRON is offline   Reply With Quote
The Following 2 Users Say Thank You to COLDIRON For This Useful Post:
kwikfishron (06-27-2011), Ron6519 (06-25-2011)
Old 06-27-2011, 08:02 AM   #4
My deck
I am building a deck all treated. Using. 2 x 10 x 16 as beams and joist with 12 ft span deck is 16.x 16 with 3 6 x 6 under each beam for supports. Would using 6 x 6 for the hand railing post be to much weight if I have them every four foot around the perimeter???
Old 06-27-2011, 11:58 AM   #5
If the deck is built correctly, you'll have no issue with the weight.
The visual ascetics are another matter. A 6x6 every 4' is a mass of wood.
Ron
B. Franklin 1759
Shoddy Pressure Treated Lumber? spanky77 Building & Construction 17 06-25-2011 08:09 AM
Pressure treated wood does or does not need to be painted???? stanlam Building & Construction 11 03-27-2011 03:04 PM
Where to buy heat treated Plywood or OSB and lumber? Spud General DIY Discussions 5 10-21-2009 09:49 PM
found treated fascia,alluminum soffits, now what 4just1don General DIY Discussions 3 05-15-2009 06:40 AM
Comment on those Special Type of Treated Wood for Deck ? KUIPORNG Landscaping & Lawn Care 4 07-04-2006 12:38 PM
