Treat This?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2006, 05:17 PM   #1
Treat this??
Does this deck need to be weather-proofed or treated somehow? I mean, do the supports need to be treated? If so, what should be used to treat it?
It would be bad if the deck started rotted or something. House is in northeast.
Thanks for your advice.
landslide is offline   Reply With Quote
Old 07-18-2006, 07:05 AM   #2
Treat
The deck should be treated with a sealer or stained to prevent wood splitting and cracking and discoloration over its lifespan.
I' m partial to CWF (Clear Wood Finish) by Flood, Wolman's Clear Wood Finish, or semi-transparent exterior stains.
manhattan42 is offline   Reply With Quote
Old 07-18-2006, 07:42 PM   #3
Thanks very much.
Do you mean the deck surface itself should be treated, or the supports underneath (shown in the photo), or both?
Old 07-19-2006, 07:40 AM   #4
I treat every bit of exposed deck lumber, but the most critical is the deck surfaces directly exposed to UV light, snow and rain...
Pressure Treated ok from sub floor down? Bpawb Carpentry 7 07-31-2006 10:59 PM
Didn't use green treat...now what? tosuwyja Building & Construction 3 03-27-2006 08:37 PM
