Transparent Carbon Fiber - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 12:19 PM   #1
transparent carbon fiber
hello everyone,
I'm thinking of building a big aquarium.
of which one side needs to be 5m height and 3M wide.
It should be transparent enough to let the light through but strong enough to resist huge amount of water.
I thought if there is something like transparent carbon fiber plates?
or materials to make them?
that could be a good solution.
or any other ideas ?
a glass or a plexiglass will be too expensive for this project .
thanks in advance .
tato
tato is offline   Reply With Quote
Old 04-25-2011, 12:49 PM   #2
Rewards Points: 5,336
Originally Posted by tato View Post
hello everyone,
thanks in advance .
tato
I'd build it outside. You don't mention a third dimension in the size. Only height and width. What's the depth?
Ron
Old 04-25-2011, 01:34 PM   #3
Ron
sorry I made mistake .
5m wide 3m high is just one wall (green wall on the photo).
I wont to build it for shooting a short film were I need to have actors swimming in front of a green screen .
this green screen is the mane problem . I need wall of some strong material which I would paint green . than I would light it evenly from beck and it would transmit light .
here you can see sketch of idea.
http://www.flickr.com/photos/2597945...ream/lightbox/
Tato
Old 04-25-2011, 01:37 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
You will need to contact Scotty, the engineer from the Enterprise but he used transparent aluminum to build a whale tank one time.
carbon fiber is not transparent, translucent, or even opaque.
and if you though glass or plexiglass was too expensive, carbon fiber would really be too expensive.
Ron
They're really really thin fish, like in so thin they are only 2 dimensional.
Old 04-25-2011, 01:44 PM   #5
Tato
Some guy awhile ago wanted to the same thing. I think the universal opinion was that the idea was not feasible due to the budget limitations.
You remember don't you, "Somethingpunk"?
Check this out:
build a large water tank/aquarium?
Ron
Old 04-25-2011, 01:45 PM   #6
Rewards Points: 1,578
"You will need to contact Scotty, the engineer from the Enterprise but he used transparent aluminum to build a whale tank one time."
, first thing I thought of! I don't think HD/Lowes carries it though.
bob22 is offline   Reply With Quote
Old 04-25-2011, 01:49 PM   #7
here are other images .
3m height/4m width/5M long
so big and thick enough plexiglass or glass sheet would be very expensive.
is there any other material which would be not so expensive but would let a bit of light through ?
Old 04-25-2011, 02:02 PM   #8
So, this is roughly 10 feet high, 13' wide, and 16 feet long? How much water does this beast hold? I assume this is meant to be installed over the ground, ie, no structural foundation using beams, joists, etc...? I figured it was about 62,000 kgs or 124,000 lbs of water (15.5 thousand gallons or 58.8 thousand liters). You best call the National Aquarium to see how they do it.
Old 04-25-2011, 03:34 PM   #9
You don't have the knowledge to build it and you can't afford to hire someone who does.
Ron
Old 04-25-2011, 04:07 PM   #10
Ron
No I don't .
and thats why I'm asking you .
I guess I will have to find other way to shot this . or build much smaller aquarium.
thank you for answers .
tato.
Running Fiber line in conduit? dataguy Electrical 3 11-07-2010 05:57 PM
if you were to pull fiber, what fiber would it be? MLMIB Electrical 15 10-06-2010 10:47 PM
min depth for fiber optic cable underground? MusicMan_234 Electrical 5 01-30-2009 12:32 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Carbon Monoxide Kills TRUSTEDTRADESMEN General DIY Discussions 1 06-23-2008 07:52 AM
