Old 03-29-2007, 03:41 AM   #1
Default % total roof load on interior bearing wall?
Hi,
Looking to improve my understanding of the forces involved in choosing a doubled/tripled LVL beam to replace a 14 ft segment of interior load bearing wall. I will be asking the LVL supplier to run figures, or may need to consult a structural engineer, but for planning I would like to understnd the process better.
House is single story, frame on slab, with 2 x 4 wood trusses spanning 30 ft with 1.5 ft overhangs. Roof is single layer of composition shingles over 1/2" ply. The 2 x 4 framed interior wall is 12 ft from one exterior wall and 17 ft from the other exterior wall, and perpendicular to the trusses.
Live Load is 20 psf, Dead Load is 15 psf, No snow load, Tributary Area for each truss is 63 sq ft. Reaction for each truss should be 2,205 lbs.
Can anyone guide me to the correct way to figure the proportion of this weight that is carried by the interior wall? In an earlier posting Phil related that in a simplified model using beams rather than trusses crossing the interior wall in question, the answer would be 5/8 of the total roof load (that would be 689 lbs per lineal ft for my case). He said trusses however act different than beams. Can anyone take us a little further?
Header span tables I have checked either don't specify exterior vs interior, or assume floor loads, or don't give spans appropriate to LVLs. Uniform roof load tables might be the answer, but I need to be able to know the actual lbs per ft., how deflection affects this, etc.
Thanks!,
Grommet
Grommet is offline   Reply With Quote
Old 03-29-2007, 09:37 AM   #2
A truss is simply a bridge, the load is being transfered to your outside walls. Each piece of a truss is placed to maximize this bridging. A beam on the other hand has to in affect surport it self so without some kind surport under it will sag and can't even begin to match a truss for clear spanning. A truss can be thought of as the rafters, collar ties and beam all rolled into one. To answer your other question on how much force or load bearing try googling under truss manufacturing or specs. Ideally you would want most of the load bearing on the outside walls, the engineered wood being manufactured is lighter and stronger than conventional stick framing.
Gary
gary is offline   Reply With Quote
More On This Topic
If moving walls is in your plan, there are several things to consider. You want to consider what is in the wall. Is there electric in the wall? Is there plumbing in the wall? Where is it? Where can you move it? Can you take it out? What would be the... Read More »
Materials for Painting
Materials for Painting by Expert Village
Hello my name is Grady Johnson. I'm a professional painter and today I represent Expert Village.com Now I'm going to talk a little bit about the materials we need for interior and exterior painting. Now whenever we're painting we know the first thing we... Read More »
Whether you need a garage for your vehicle or extra storage it will be a wise investment for your home. The plans for a garage can be purchased off the Internet instead of using a high priced architect because of the simplicity of the design. If you want... Read More »
Eco-friendly walls are good for the environment, your health and your bank account. Walls that consider environmental and ecological factors insulate better and use less costly and damaging materials in their construction. Read More »
How to Paint a Door Jamb
How to Paint a Door Jamb by Expert Village
Hello! My name's Grady Johnson and I'm a professional painter. And today I represent expertvillage.com. Okay, now we're going to talk a little bit about painting the interior door jambs. Now, when you're painting interior door jambs, the thing to... Read More »
Load Bearing Wall or not?? dtmbizzle Building & Construction 3 07-16-2007 09:12 AM
Roof Sagging wall bowing christy123 Carpentry 37 12-29-2006 06:16 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 03:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 03:01 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 09:43 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
