Total Air Tool Beginner Question (real E-z) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-30-2007, 11:34 AM   #1
Rewards Points: 1,062
Question
total air tool beginner question (real e-z)
which type of oil is (best) to be used with my makita air compressor ?
http://www.amazon.com/Makita-MAC2400...9036010&sr=1-1
Old 12-30-2007, 12:23 PM   #2
(the original)
Rewards Points: 756
Air compressor oil, which is basically just a high grade non-detergent 30W. I suggest you read your manual thoroughly before you do anything else...
Excellent choice of the Makita, as long as you don't have to move it around a lot. It's a heavy beast, but a lot quieter than anything else in its class.
ratherbefishin' is offline   Reply With Quote
Old 12-30-2007, 12:47 PM   #3
The manual on page 10 calls for "air compressor oil" to be used. It's sold in bottles along with other air tool accessories. The main thing is that it be a straight-weight, non-detergent oil.
XSleeper is offline   Reply With Quote
Old 12-30-2007, 12:56 PM   #4
Union HVAC Tech.
I have had good luck with porter cable brand oil.
bigMikeB is offline   Reply With Quote
Old 12-30-2007, 08:56 PM   #5
remodeling pro
Like they said, be sure it is "air compressor" oil, readily available at tool dept of Lowes/HD. Never use light weight motor oil or anything that contains detergents, they will attack the seals in the compressor.
troubleseeker is offline   Reply With Quote
