Torn Interior Building Paper - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-10-2010, 08:16 PM   #1
Torn interior building paper
This house was built in the 40s. I removed some drywall and found building paper on the inside. I thought its suppose to be on the outside...
Also it had been painted over and patches of it are torn.
What is this for and is it an issue that its torn?
acerunner is offline   Reply With Quote
Old 09-15-2010, 07:02 PM   #2
Registered User
Rewards Points: 5,236
It should be on the other side of the sheathing boards as a water resistant barrier. Inside it is acting as a vapor retarder:
http://www.energysavers.gov/your_hom.../mytopic=11810
Gary
Old 09-15-2010, 07:13 PM   #3
well, there was also kraft faced insulation w/ paper on the interior side. That means two vapor retarder layers? Isn't that a no no, or does that only apply to vapor barriers?
Old 09-15-2010, 08:50 PM   #4
Registered User
"that only apply to vapor barriers?" ----- correct. The felt will let moisture through with a perm rating of 6 when dry and 60 when wet. http://www.dickseibert.com/martin.pdf
Vapor barriers are actually a Class of vapor retarder: http://www.buildingscience.com/docum...gs?full_view=1
Gary
Drywall - fixing patches from torn off glue DK75 Drywall & Plaster 8 09-09-2015 07:31 AM
To remove or not to remove tar paper, that is the question Jeremy Hillary Boob, PhD Building & Construction 4 02-27-2011 09:34 PM
Help -Tar Paper on basement walls atm Building & Construction 9 09-29-2009 12:41 AM
Felt Paper and the Sun. Valley problems hartkem Roofing/Siding 1 07-22-2009 04:57 PM
contact paper removal scatterbrain Remodeling 2 07-06-2008 08:57 AM
