-   -   Top plate nailing protective plate for pipe (http://www.diychatroom.com/f19/top-plate-nailing-protective-plate-pipe-184745/)
bryanp22 08-04-2013 03:00 PM
1 Attachment(s)
I need to put my top plate right in the middle where this protective metal plate is below the water pipe. What are my options? Can I just attach a small block of 2x4 to the side of the joist and then attach the top plate to the block? I am not sure on the proper way to do this.
gregzoll 08-04-2013 03:36 PM
Pull that Copper out, and pull PEX in its place, higher up where it is supposed to be. Of course that Electric is in the middle, which I would have never done, but whoever did it, must have thought someone would be driving in long spikes into those joists.
In reality, your wall you are building is not going to be load bearing, so even if you place it up there, you could secure it along the backside of where that Copper is, and leave the piping alone.
bryanp22 08-04-2013 05:13 PM
Yeah can't move plumbing myself city wont let me pull a permit so that has to stay. What else can I do?
gregzoll 08-04-2013 08:05 PM
Uhm, yes you can. In this case, you can pull that offending pipe, and place the PEX where it should be. It is called an Emergency situation, and the city would not know, unless someone goes blabbing to them.
Figure a Sawz-all at every other joist, you can cut that sucker out, and pull the 3/4" PEX up away from where you are placing the wall.
joecaption 08-04-2013 08:06 PM
Why would you need a permit to just move a pipe?
gregzoll 08-04-2013 08:36 PM
That is what I asked, when I made my last reply. I am guessing that the OP is afraid the Black copters are hovering over them all the time, when they go to and from the Big box store.
bryanp22 08-04-2013 09:40 PM
My city has been known to notice new construction when inspecting other items and assessing fines.
gregzoll 08-04-2013 10:05 PM
There is no way of them seeing any piping being changed, again, unless someone runs their mouth. As for the basement remodel, again, if you follow codes, and do it properly, there is nothing they can do with you regarding moving that piping which was installed incorrectly in the beginning.
BTW, if you go through your town, you will find quite a few basements finished, no permits pulled, and everything is up to code, with the exception of those who scab the jobs together, just like your Copper pipe which clearly states Hack job.
