Top Plate Of A Frame Under/Along A Metal Basement Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 02:28 PM   #1
Can I Have a Top Plate Under/Along a Metal Basement Beam
Hello everyone. First post from me. A big thanks to all the great information I've gleaned from all of you so far.
I've insulated my basement (rigid foam glued to walls) and am about to start framing. I'm adding two interior walls, one of which runs along a metal support beam for about 6 feet. I need to run along that line because there are obstacles on either side that make attaching the top plate difficult (see picture). I know there are options to construct around obstacles but I'm hoping there is a good way to attach the top plate along that metal beam and simply stick frame it from there.
The wall will be dry-walled up to the beam, but the beam itself will remain exposed and painted.
Any ideas?
Top Plate of a Frame Under/Along a Metal Basement Beam-beam.jpg
milwaukeemike is offline   Reply With Quote
Old 04-02-2011, 03:05 PM   #2
Rewards Points: 6,652
Carpenter's nail would work. Personally, I would place framing supports down from the joists, then attach the framing for the wall to that.
Old 04-02-2011, 03:15 PM   #3
Old School
Willie T's Avatar
Most of the time in those installations the top plate is simply "shot" into the metal beam with a high power cartridge nailer. A little intimidating if you've never dealt with those guns, so I don't recommend it for DIY.
There are so many great adhesives on the market today that it makes better sense to make your wall height pretty tight fitting, and just use a good adhesive to glue the wall into place.
Willie T
Old 04-02-2011, 07:43 PM   #4
My suggestion would be to drill holes in the web of the beam on 24" centers and bolt the top plate to the bottom with carriage bolts.
Old 04-02-2011, 09:33 PM   #5
concretemasonry's Avatar
Rewards Points: 2,652
Wilde -
Do you mean the beam flange or the beam web?
Dick
concretemasonry is online now   Reply With Quote
Old 04-02-2011, 10:53 PM   #6
Originally Posted by concretemasonry View Post
Wilde -
Dick
The flange! Its my take that he wants to fasten the top plate of the wall to the underside of the beam.
Old 04-03-2011, 09:04 AM   #7
Thanks for the help, everyone. I had dinner last night with my friend, a construction architect, and ran this by him to get his opinion. He felt that given the short length of the wall, using a strong adhesive along the top and building it with a tight-fit would be sufficient. His suggestion for a longer wall in this situation was exactly what 'Wildie' suggested -- drill a couple holes in the beam's bottom and bolt the top plate to it.
Thanks again!
Tags
frame , top plate
Question about steel I BEAM in basement djohns10 Building & Construction 7 06-23-2012 03:55 PM
Basement beam concern Rife Building & Construction 1 07-11-2010 12:16 PM
Cracked Basement Beam lpcon Building & Construction 12 04-12-2007 07:47 AM
Removing cement walls in basement / replacing with I beam bbockstanz Building & Construction 9 11-19-2006 06:31 AM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 06:36 PM
